Previous in Forum: Flow Merging and Dividing   Next in Forum: Telescopic Cylinder (Double Acting)
Turbine Ramping
04/15/2010 1:24 PM
WHAT IS TURBINE RAMPING?
Good Answers: 60
Re: TURBINE RAMPING
04/15/2010 2:03 PM
just lately there seems to be a lot of these questions with no info.
i would have to guess its about fitting a turbo charger,
but as the question does not mention in relation to what?
http://www.eng-tips.com/viewthread.cfm?qid=251759&page=1
Re: Turbine Ramping
04/15/2010 5:30 PM
Ramp rate is used in bringing a turbine up to operating temperature and is the degrees Fahrenheit rise per hour that metal surfaces are exposed to when bringing a machine to rated conditions. Manufactures specify ramp rates for their machines in order to avoid thermal stresses. Thermocouples are used in measuring metal temperatures.
ALL CAPS IS CONSIDERED SHOUTING!
By the way, would your classmates not share their notes with you? If you would Google a little bit, you could find all kinds of stuff about steam turbines, airplanes, magnets, rocks, firecrackers, horses, plants, the moon...
Register to Reply 2 comments
