Previous in Forum: Electrode Qualification   Next in Forum: DG Efficiency
Welder Qualification
04/16/2010 2:16 AM
Dear All, can we qualify a welder with U.T., MPT, DPT instead of R.T.? if yes by which code?
Re: welder qualification
04/16/2010 2:17 AM
this is getting ridiculous.
TELL US WHAT CODE YOU ARE TO FOLLOW, RATHER THAN YOU RANDOMLY CHOOSING WHAT SUITS YOUR NEEDS!!!!
04/16/2010 2:24 AM
And to try and convince you how ridiculous your question is:
What are you welding? Structural, piping, vessels, pipeline, railroads, military vehicles, underwater, cranes, automotive, tanks, aerospace, boilers, ships/marine .....
04/22/2010 9:28 AM
API 1104 and 1" pipe welding
04/16/2010 2:57 AM
And, while you're at it, what are UT, MPT, DPT, and RT? And why do some of these have periods and others not?
04/16/2010 10:42 AM
Ornery Guest #1/2 here -
UT - Ultrasonic Testing
MPT - Magnetic Particle Testing (more properly abbreviated MT)
DPT - Dye Penetrant Testing ((more properly abbreviated PT)
RT - Radiographic Testing (X-ray)
Re: Welder Qualification
04/17/2010 9:33 AM
As the above guest has correctly pointed out.
- Please decide on the code that you want the welder to be qualified for - ASME? API? DIN? EPV?...
- Structural, Pipeline, pressure Vessels ? ...
- Write the WPS and PQR for the code.
- Get the welder qualified for the same (WQR)
Once you have decided on the code (and please remember the welder qualified for ASME is not automatically qualified for API ... for example)
And the same goes on for the electrode, only that may feature in the PQR portion (since electrode is a part of main process variable)
Of course if it is from any of the standard reputed manufacturer, this portion you may skip (LE, ESAB,...) but that does not seem to be the case.
Register to Reply 6 comments
Anonymous Poster (4); msurendra (1); Tornado (1)
You might be interested in: Bar Code Scanners, Bar Code Cards, Bar Code Software
