Previous in Forum: Single Conductor Interturn Fault   Next in Forum: Star Delta Diagram
How To Calculate Cable Burden
04/18/2010 6:08 AM
what is mean by Cable burden ? how to calculate burden value of cable?
Re: Mr
04/18/2010 8:49 AM
You don't really give enough information to explain which possible version of cable burden you have. You might be talking about the equations that make a catenary curve. You may need to know the tensile strength of a cable. You could even be referring to collisions in computer science. Lastly you might even be wondering about the harness strength for your donkey.
Good Answers: 244
Re: Cable burden
04/18/2010 10:55 AM
The cable burden is the load (in VA) imposed to CT secondary due to the cable resistance. When considered the CT load, the cable burden is also added to the other loads used in CT secondary.
The CT secondary load = Sum of the VA's of all the loads (ammeter, wattmeter, transducer etc.) connected in series to the CT secondary circuit + the CT secondary circuit cable burden.
Cable burden = I2 x R x L
Where
I = CT secondary current,
R = cable resistance per length,
L = total length of the secondary circuit cable.
If the proper size and short length of wire is used, cable burden can be ignored.
See also http://cr4.globalspec.com/comment/448082
- MS
Register to Reply 2 comments
You might be interested in: Cable Laying Services, Cable Assemblies, Cable Trays
