Previous in Forum: level measurement   Next in Forum: Instrument Cable
Interfacing A 7 Segment Disply Unit
04/18/2010 9:45 AM
How do I make my Allen Bradly SLC 5 output 30 minutes count on my 4 Digit, 7 segment display unit. Is there a function block in the RsLogix 500 that can convert this 30 minutes timer. Th 4 digit display unit has 4 disply strobes for A, B , C, D and 4 latch for each digit disply.
Engineering Fields - Control Engineering - Control Engineering Technical Fields - Education - Industrial Training Engineering Fields - Manufacturing Engineering - Manufacturing Training Engineering Fields - Electrical Engineering - Electrical engineering Training Engineering Fields - Instrumentation Engineering - Instrumentation Engineering United States - Member - New Member Engineering Fields - Energy Engineering - Become part of the larger group, change your world.
Re: Interfacing A 7 Segment Disply Unit
04/18/2010 10:25 AM
Using the ASCII function is nice but won't work with your limited hardware. You will have to use the TOD instruction to convert your timer accumulated value (T4:5.ACC) to BDC (Binary Coded Decimal). When rung conditions are true, this output instruction converts a 16-bit integer source (timer ACC value) value to BCD and stores it in the destination register (memory location).
See PLC Tutorial BCD - Binary Coded Decimal ...
http://www.youtube.com/watch?v=TDcC_WkJt08
AB PLC Training onsite, On-Line, training software and more. BIN95.com
