Previous in Forum: DC Motor Encoder Fittment Arrangement Run Out Requirement   Next in Forum: Electrical Energy Audit
11 / 0.433 kV Transformer
04/19/2010 4:08 AM
For 11/.433 KV transformers.
If the HT cable length exceeds 50 m length, whether it is compulsory to have HT breaker near to transformer (at 11kV side) or not as per IEC standards?
Thanks in advance for the replys.
Engineering Fields - Electrical Engineering - Hentoyk Philippines - Member - BRUTUS Saudi Arabia - Member - Brutus United Arab Emirates - Member - Brutus
Re: 11 / 0.433 kV Transformer
04/20/2010 1:40 AM
Maximum of 3m distance in between electrical equipment from where the transformer is tapped needs to provide a circuit breaker as disconnecting means.
If there is a will... there is a way... No pain / No gain.
