Previous in Forum: 460V 60 Hz Motor Operating at 380 Volt 50 Hz   Next in Forum: Induction Motor Traction Drive
Constuction of Current Limiting Reactors
04/20/2010 1:50 AM
Why current limiting reactors put in system are of air cored construction?
What are other specific features?
Re: Constuction of Current Limiting Reactors
04/27/2010 6:15 AM
Because air can not store significant energy.
For instance a lighting spike is expended forming a magnetic flux, but there is little energy return.
If you put a metal or ferrite core in the coil, then it would return energy - to the downstream equipment.
Kyzine
04/28/2010 8:00 PM
Also helps with cooling ... maybe?
Register to Reply 2 comments
You might be interested in: Current Limiting Diodes, Reactors, Process Reactors
