Previous in Forum: Vent hole in SORF flange   Next in Forum: Blind Bonnet flange
Indonesia - Member - Member from Indonesia Engineering Fields - Mechanical Engineering - Mechanical Engineer Popular Science - Weaponology - Weapon Fan Safety - Hazmat - Safety First! Hobbies - Automotive Performance - Tuner Wannabe Hobbies - Target Shooting - I'm a good shooter
[ASK] Designing Cone-Bottom Tank
04/20/2010 3:49 AM
Dear Member,
What is the standard for designing cone-bottom tank with flat roof?
This tank is a storage of base oil for lubricant and the material is A-283 Gr C. The picture of tank is below. Thanks you for any feedback..
Please give respectful & positive answer than insulting! Respect each other ok..
Location: Next to the Prime Merridian (51°29'34.50"N 0°13'32.85"W)
Re: [ASK] Designing Cone-Bottom Tank
04/20/2010 4:05 AM
I could give you some hint on its construction but nothing about standards. In fact, I would be interested myself how to follow that up and with whom as I doubt the local council is good enough.
We used to make these @1000cubic meters and the bottom part (cone with column studs) weighted around 125 tonnes and was heat treated to 1100 degrees Celsius prior to seat it on the support columns.
Making mistake is part of learning.
04/20/2010 8:38 AM
How about:
BS EN 1993-4-1:2007
Eurocode 3. Design of steel structures. Silos
http://www.techstreet.com/cgi-bin/detail?doc_no=BS_EN|1993_4_1_2007&product_id=1402447
04/21/2010 11:21 AM
How big is this tank gonna be?
As I see the code book ain't cheap and at this stage it looks as if the support columns might have to be extended up on the side of the tank (meaning the cone and the lower end of the cylinder has to be the same gage) if the tank is a monster size.
Register to Reply 3 comments
