Previous in Forum: Driveway Gate - Part 2   Next in Forum: AWWA C900 VS AWWA C909
Double Overlap Test
04/20/2010 7:39 AM
Does anyone know the meaning of "Double Overlap Test"? what test is it ? coz this test seems to be related to the psysical property of this fluorogold which is a specially formulated Teflon.
I am not a home work cheater. I am a translator seeking professional help
Re: Double Overlap Test
04/20/2010 9:10 AM
When testing adhesive shear strength you use a test referred to as a lap shear test. Normally 1" wide x 6" long samples of some thickness are bonded to each other with a 1/2" overlap. This gives a 1/2 square inch area of bond.
A single overlap joint is subject to warpage and bond failure due to peel failure. Double overlap joints allow a straight pull with no warping and associated peel failures.
So, we had a double overlap adhesive strength test. Or, a double overlap test.
Something like this:
Strength Properties of Double Lap Shear Adhesive Joints by Tension ...
Good Answers: 183
04/20/2010 11:13 AM
I am not 100% sure but I met this denomination for above test which makes sure that the bond is loaded ONLY in shear.
Good Answers: 114
04/20/2010 1:02 PM
So it's a test of the epoxy bond.
04/20/2010 1:14 PM
Yes.
Register to Reply 4 comments
lyn (2); nick name (1); passingtongreen (1)
