Previous in Forum: Transformers   Next in Forum: SAMPLE PROJECT FOR AUTO TRANSFORMER
Motor Heating Problem
04/20/2010 2:54 PM
hi, i have installed a 56 kw induction motor with pump. but at the time of starting with load it's heating. i have all ready checked the alignment it is ok. it is all so taking rated current volt is also normal. what may the problem.
imolla
Good Answers: 29
Re: motor heating prblm
04/20/2010 3:18 PM
Motor type?
Source voltage?
Data tag info?
Pump type?
Unit history?
What's it pumping?
Specifics please.
India - Member - design engineer Engineering Fields - Electrical Engineering - New Member United Arab Emirates - Member - New Member
Re: motor Heating Prblm
04/21/2010 3:01 AM
M
Have u used starters in your circuit? If not use it .....probably ur problem s wit inrush current.....if u want complete details then provide us wit complete data ......
shamith gambhir, electrical engineer
Good Answers: 804
Re: Motor Heating Problem
04/26/2010 3:53 PM
Define "heating" first.
When motors run, they get hot. Surface temperature means next to nothing, modern motors generally run too hot to touch comfortably. The only valuable motor temperature information would need to come from internal temperature sensors such as RTDs embedded in the stator. If you are determining that the niotor is "heating" because it is warmer after you start it than it was before hand, that means nothing more than it is working.
Register to Reply 3 comments
JRaef (1); RDGRNR (1); SHAMITHGAMBHIR1 (1)
