Previous in Forum: Branch Size on Header   Next in Forum: Underground Hydro Test
Ultrasonic testing
04/22/2010 9:17 AM
Dear All, Can we ultrasonically test a butt weld at pipe thickness less than 4 mm?For which minimum thickness we can successfully test a butt weld in a pipe with angle probe?
Re: Ultrasonic testing
04/22/2010 10:00 AM
To correctly interpret ultrasonically test, the thickness of the test parts should not be less than 8 mm. See also code case 2235-3 of ASME BOILER AND PRESSURE VESSEL CODE.
04/26/2010 9:40 AM
The are a lot of variables to your question-material,defect size and type, sizing accuracy needed,code etc. Ultrasonics are routinely applied to butt welds at less than 4mm with varying results. The poster below mentioned 2235, but in comparision there is B31.3 CC 181 with no minimum thickness. The whole application, code requirements etc need to be reviewed. Often with thinner materials the test may become essentially go-no go type results but not necessarily. There have been a lot of developemnts in ultrasonic equipment, especially in phased array transducers (curved in passive axis etc) that allow for thinner materials to be tested. Sizing ultrastraonically essentailly comes down to beam size, while detection is a bit more varied.
India - Member - Mechanical Engineer Engineering Fields - Petroleum Engineering - Mechanical Engineer
05/25/2010 10:55 AM
if i'm not wrong the preferred test on butt weld is a radiography. how ever ASME section V will be more helpful for this.
Varun Passi
Register to Reply 3 comments
Anonymous Poster (1); schab (1); varunpassi (1)
