Previous in Forum: Car Body   Next in Forum: Ford Engine Transplant
Older Single Carbs
04/22/2010 12:57 PM
Often it is not just the idle speed that needs to be changed but a slight adjustment to the electrical timing. This should take care of you stalling when clutch is used at stop light. If this does not completely fix problem then increase you idle RPM slighty. This should do what you need.
Re: Older Single Carbs
04/23/2010 2:08 PM
Wow. Another solution to a problem I don't have Thanks!!
Reply to Forum Thread
