Previous in Forum: Using Laser Light for Alignment Testing / Setting   Next in Forum: S40 Pipe
Stirling Engine Question
02/12/2007 9:03 AM
i hve posted 2 question in the past n ive got very gud help frm all of u....thank you guys a lot.
this time im goin to ask u about stirling engine.
one of my teachers he asked me to do for my Bsc Eng degree project a hybrid stirling engine that uses exhaust gas heat to heat up the fluid in stirling eng and use it as a hybrid with ICE.....now my question is how much temp should the exhaust gas has to be and how much power it can produce form a stilring engine....and which type of design i can use......hope this is not to much that im asking form u all....i just want a lead so that i can start. hope ill get many information....plsz
thank you
Pathfinder Tags: stirling engine
Re: stirling engine
02/12/2007 9:14 AM
Re: Stirling Engine Question
02/23/2007 12:19 AM
Don't look like you are getting a lot of help on this one. My best suggestion would be, go to the library and look for a book on stirling engines. Some are quite elaborate some are quite simple. Heat requirements also run the gambit. Sorry couldn't be of more help
Register to Reply 2 comments
