Previous in Forum: Flange Facing Finish   Next in Forum: vrv system
What are the differences between Globe valve and Gate valve?
04/25/2010 11:46 PM
These valves are related to petrolium industry.
Pankaj
Re: What are the differences betwwen Globe valve and Gate valve?
04/26/2010 1:45 AM
Gate Valves have a large slab that lowers down into a cavity at the bottom of the valve. They care sometimes fitted with a drain so you can bleed the cavity dry to prove that the valve is sealing correctly and no flow can by-pass it. This is useful for when you have to do work on a tank and need to be sure no product will go into the tank through that valve. Gate valves also open fully and can allow a pig to pass unobstructed.
Glove valves have a plunger like assembly that lowers down into a sealing face. They are usually used where flow control is required and you do not need to pass a pig through the line.
Here is a picture of a globe valve
and a Gate Valve
Drew
04/26/2010 1:49 AM
Thanks GURU
Pankaj
Register to Reply 2 comments
You might be interested in: Solenoid Valves, Control Valves, Gas Valves
