Previous in Forum: transformer no-load current test   Next in Forum: sealing rod in heat exchangers
Characteristic impedance calculation of a transmission line
04/26/2010 8:13 AM
A transmission line section shows an input impedance of 36 ohm and 64 ohm respectively, when short circuited and open circuited. What is the characterestic impedance of the transmission line.
The important thing is not to stop questioning.
Re: Characteristic impedance calculation of a transmission line
04/26/2010 8:17 AM
04/26/2010 8:31 AM
This appears to be a homework question.
In general the CR4 community is good at helping each other. Officially we are not a homework cheat site. Unofficially there are mixed opinions, but in general homework help is only "limited" and "help". If you want someone to do your homework for you I suggest you offer a pizza to the smart looking student in the second row. If you want to do your own work and need a little help then it is important that your posting indicate that you have done work and helps us understand what part of the problem is causing the trouble.
04/26/2010 11:10 AM
This is not a home work question buddy. It is one the question asked in Engineering services examination. I know and understand the concept of surge impedance. Please help me in giving the answer rather than passing comment.
04/26/2010 11:24 AM
Sorry for the trouble guys, Finally i googled it out. I am pasting the formula for users understanding. Short For the case of a shorted load (i.e. ZL = 0), the input impedance is purely imaginary and a periodic function of position and wavelength (frequency) Z(in) = Z(0) x tan(beta x l) Open For the case of an open load (i.e. ), the input impedance is once again imaginary and periodic Z(in) = Z(0) x cot(beta x l) Where beta refers to wave number and 'l' refers to length. Using given values, we get 36 = Z(0) x tan(beta x l) ----- (1) 64 = Z(0) x cot(beta x l) ----- (2) Multiplying (1) and (2) we get, 36 x 64 = Z(0) x Z(0) ==> Z(0) = 48 ohms
Register to Reply 4 comments
