Previous in Forum: Characteristic impedance calculation of a transmission line   Next in Forum: variable current control with 220v AC circuits
sealing rod in heat exchangers
04/26/2010 8:26 AM
what is the main function of using sealing rod in heat exchanger?
Re: sealing rod in heat exchangers
04/26/2010 8:29 AM
Leak risk reduction?
04/26/2010 8:38 AM
i don't understand your reply please verify
Good Answers: 60
04/26/2010 9:55 AM
04/27/2010 12:30 AM
I wonder if the unfamiliar term "sealing rod" refers to a tapered plug driven into the end of a tube to isolate leaks within the tube....
04/29/2010 3:16 AM
Another way of doing it is to fill the leaking tube up with concrete.
design2000 (1); peterg7lyq (1); PWSlack (2); Tornado (1)
You might be interested in: Heat Exchangers, Sealing Machines
