Previous in Forum: Gun Metal LG2 and PB Difference   Next in Forum: Piping Engineering - Statutory Regulations
Oil and Gas Processing
04/26/2010 8:23 AM
please,i want a brief description of oil and gas processing focusing on the commodities used in that
thanks in advance
Location: The cigarette-stained drunkard living in the cardboard box outside Marks & Sparks delivery entrance, Eastgate Shopping Centre, Basildon.
Re: oil and gas processing
04/26/2010 8:25 AM
Then you really want an internet search engine. £20! <Splutter>
Essex jobs for Essex yobs! <Burp>.
Good Answers: 60
04/26/2010 9:58 AM
Good Answers: 244
04/26/2010 12:02 PM
The major equipment used in Gas processing plant:
Separator, Gas Dehydrator, Compressor, Cooler etc.
The major equipment used in Oil processing plant:
Separator (HP, IP, LP), Desalter, Cooler, Heat Exchanger, Hydrocyclone, Gas floatation, Water Injection Pump, Water Lift Pump, Gas Dehydrator, Gas compressor (HP, LP), Knock-out (KO) Drum, Flare etc.
These are the equipment used in conventional processing plant. Equipment used in non-conventional plants (Oil-Sands, Shale oil, CTL, BTL, Shale Gas, CBM etc.) are different.
See this link for more details about the processing:
http://subsites.bp.com/caspian/ACG/Eng/Phase3_v2_nov_04/05%20Ch05_09-04/05%20Chapt%205%20PD%20Section%205.5%20Process_ENG_FINAL_Oct%2004.pdf
- MS
Register to Reply 3 comments
msamad (1); peterg7lyq (1); Stinky Pete (1)
