Previous in Forum: HNC Coursework Help   Next in Forum: Drainage and Sanitation in the Dharavi slum, Mumbai
12 comments
Column Deviation From its Position
04/27/2010 5:44 AM
Dear engineer.
I need your advise on deviation of column from its position.
It happen contractor setup columns out of its position by 75mm in which if allowed to proceed will protude out the wall by 75mm because it flashing with the wall in outside and if we need to return to the required position all reinforcements are supposed to be cranking in one direction which is not recommended in codes of practice because of buckling effects.
Please advise in the situation like this what we supposed to do?
Re: Column Deviation from its position
04/27/2010 6:58 AM
Who made the mistake?
04/27/2010 7:02 AM
Wasn't me
Re: Column Deviation From Its Position
04/27/2010 10:32 PM
Would knowing make the answer to the question easier?
04/28/2010 6:43 AM
Yes. Please follow the link in Del's post #4
04/28/2010 12:35 PM
Contractor made mistake then need attention of consultant
04/28/2010 6:07 PM
"Contractor made mistake ..." - then it's the contractor's responsibility to fix it.
04/27/2010 7:26 AM
Rip it out and replace it.
04/27/2010 7:35 AM
It's a bit like this thread...
If all else fails, try doing it to the spec.
Good Answers: 53
Re: Column Deviation From its Position
04/27/2010 12:47 PM
Let it protrude 75 mm ( if its not in your neighbours land). adjust column section for added span of 75mm.
usual disclaimer applied.
04/28/2010 10:09 AM
You might begin by telling us how big the column is.
Does the 75mm represent 1% of the column dimension or 75% of the column dimension?
04/28/2010 12:30 PM
Column size is 500X500 and column was supposed to set up at the centerline of gridline .Now is out of position by the deviating of 75 mm.This is at Raft foundation level.What is the way forward to correct problrm like that.
Best regards.
Good Answers: 19
04/29/2010 3:35 AM
Given the information provided so far:
- 75mm out of tolerance
- 500x500 post
- raft foundation
Can I assume the following:
- you have a +/-20mm positional tolerance in your spec for the position of columns
- the raft foundation has either shear rails or shear links and also has a local thickening at the post position to take the shear around the post
- it is a raft foundation and your post is probably designed as a simply supported post with no moment connection to the raft (unless you have done so specifically)
- your post is designed with probably about 3%-4% steel reinforcement (although it is the lowest post in the structure)
- a 500x500 post makes it sound like a 6 storey building (this is a hazardous guess but given that you have come to this forum, I assume that you are not talking of a very important building)
Advice is:
- it is the contractor's error and in your spec you have clauses that say that the contractor is to propose a solution for the consultant's approval
- the contractor should employ an engineer to show how he is going to rectify things so that they are the same as the architect originally intended
Practically this amounts to:
- reducing the size of the column (by about 50mm on one side out of the 500mm post) and perhaps installing some additional re-bar by drilling in chemically bonded re-bar e.g. resin anchors as deep as the raft allows
- decrease one dimension and increase the other so that it is now 450x550
- increasing the concrete strength for the post concerned from say RC40 to RC50
- getting calculations from the contractor which show that the proposed new set-up works
omw7
Register to Reply 12 comments
Anonymous Poster (2); JohnDG (3); lyn (1); nyimboh (2); omw7 (1); rakesh_semwal (1); user-deleted-1105 (2)
