Previous in Forum: Air Consumption Rate for Control and Shutdown Valves   Next in Forum: Signal & Control Cables
Drum Level Deviation
04/27/2010 5:53 AM
We are having 3 drum level transmitters in our boiler.The reading of the transmitters are widely different.the range of the transmitters are 0 to 860 mm H2O.the working range of the transmitters is +430 to - 430 mm.Can there be any problem with the compensating curve.What can be the other reason for this deviation?
Re: Drum level deviation
04/27/2010 7:00 AM
Not my field, but...That doesn't make sense to me as the second pair of figures isn't a subset of the first pair of figures.
Some figure to illustrate 'widely different' might help?
Are the transmitters the same type?
Re: Drum Level Deviation
04/29/2010 5:26 AM
What sort of level transmitters - are these actually differential pressure instruments (if so then ranging one below zero makes little sense at the moment)?
You might be interested in: Drum Pulleys, Drum Heaters, Sensor Transmitters
