Previous in Forum: Where Do the Electrons Go?   Next in Forum: High Pressure Air Properties
Photosynthesis
02/12/2007 10:07 PM
If I dissolve chlorophyll in a beaker full of carbonated water and shine a light on it, will photosynthesis occur?
Re: Photosynthesis
02/12/2007 11:34 PM
That would be impossible. But you´re welcome to try. Just don´t forget to use UV light. It simply won´´t work because photosynthesis is not a single or simple chemical reaction but a complex series of bioreactions. Photosynthesis is what gave life to the planet.The recipe for the process is descriibed in the Crebbs Cycle. Look it up.
Good Answers: 247
Re: Photosynthesis
02/13/2007 12:00 AM
This article descibes MIT's efforts. You are not alone in your desire to make photosynthesis work in a beaker.
Re: Photosynthesis
02/14/2007 1:10 PM
If the idea is to absorb CO2, then lets go planting trees. Each non-baby human, say some 4000 million persons should plant some 100 endemic trees each year, and the CO2 problem would be solved. If just a 20% of the trees survive and grow, this means 80'000'000'000 trees. If possible we should plant fruit trees endemic of each region. I wonder why nobody even mentions this obvious solution, not even All Gore. But this is the obvious solution.
We should begin planting before Mother Nature does in a much violent way, as in the carboniferous period. You may not even walk inside a dense carboniferous forest, unless you have wings.
Jaime Soto
Chile
Anonymous Poster (1); Blink (1); coffeebean (1)
You might be interested in: Plant Growth Chambers, Respirometers
