Previous in Forum: Photosynthesis   Next in Forum: Is the Enigma a "computer"?
High Pressure Air Properties
02/13/2007 4:15 AM
I am interested in calculating physical and thermodynamic properties of dry air at pressures upto 150 bar and temperature upto 1500 deg C. Specifically I need viscosity and thermal conductivity values in particular. Can somebody help? Is there a freeware or free source that I can get access to or download? thanks.
Good Answers: 120
Re: High Pressure Air Properties
02/14/2007 12:19 AM
try a search for nitrogen at that T and P, as here. There may be a greater body of work online and once you find it, you can drill down and see if they have data on air.
You can add terms like -abc and +def to fine tune and prune the hits to a smaller number. High performance jet engine makers work at least partly into that regime, temperature wise, but not pressure wise, and they may have tables that do reach your area of interest and they may share them with you if your interest is scholarly and not competitive.
http://www.google.ca/search?hl=en&safe=off&q=%22high+temperature%22+%2B%22high+pressure%22+%2Bnitrogen+%2Bthermodynamic&btnG=Search
http://www.google.ca/search?hl=en&safe=off&q=%22high+temperature%22+%2B%22high+pressure%22+%2Bair+%2Bthermodynamic&btnG=Search
Per Ardua Ad Astra
02/14/2007 1:01 AM
Thank you very much. I shall try the suggested strategy.
Register to Reply 2 comments
