Previous in Forum: Forging in Control Valves   Next in Forum: McPherson Strut Suspension and Torsion Bar Suspension
Tapered tube
02/13/2007 2:38 AM
Dear Members,
I need information about rolling tapered small tubes from sheet metal(steel or stainless steel).Lenght:100-300 mm/small dia:4-30/big dia:8-50.If some of you has this information I will be glad to receive your mails.Thanks in advance.
Best regards.
Re: Tapered tube
02/14/2007 12:59 AM
Get these ready
  • Taper blank-- two ends circular-- sectors
  • Taper Mandrel Driven rolling mini-mill with open end at Taper roll/or all 3
  • Butt edge pre-forming hand/power Press for pre-bending butt joint edges
  • Pneumatic/mechanical butt joint holder
  • TIG welding machine
  • MIG/MAG welder
  • Seam Welder--- resistance welding roller feeder
Rest is --DO IT.
If You Want Seamless-then you begin with Cylindrical blank correct sized at small end and then bring to final form in a forge-rolling -piercing special mill.
Re: Tapered tube
02/14/2007 2:12 AM
Dear Mukulmahant,
I red your biography and appreciate your ideas.I am 63 and still working as a glass mold designer .I am proud of working with such a nature friendly material.Economy is my life style.I believe that every product has a point to be simplified.
I thank you for your kind comments.Would you please sen some more details especially for first 4 sections.
Best regards.
Re: Tapered tube
02/14/2007 10:02 PM
Dear sgokben,Can you please send me your postal address--
My ID <mikemahant@hotmail.com>
BR
Re: Tapered tube
02/15/2007 12:43 AM
sgokben@gmail.com
Best regards
Re: Tapered tube
02/18/2007 11:03 AM
I am not sure what your application is, but I do remember seeing an article on TV one time regarding musical wind instrument manufacturers with some extremely interesting methods of of making all sorts of tapered brass tubes. unfortunately I cannot direct you to any specific Web site, but this might give you a guide.
Re: Tapered tube
02/18/2007 12:54 PM
Dear Garth,
Thanks for your help.
Regards
Anonymous Poster (2); garth (1); MUKULMAHANT (1); sgokben (2)
You might be interested in: Cores and Tubes, Microwave Tubes, Vacuum Tubes
