Previous in Forum: Sinosoidal Voltage   Next in Forum: Construction of EHV cables
DOL Starter Question
04/29/2010 12:04 AM
why dol starter is not used after 15kw motor rating?
Re: dol
04/29/2010 12:25 AM
In what jurisdiction? I have seen many DOL starters above that range, though oftentimes there is good reason to pick star-delta, autotransformer, or solid-state soft start, or even VFD.
Good Answers: 141
Re: dol
04/29/2010 1:07 AM
I know places where you can use it up to 50 kVA. It depends on the quality and capacity of the supply and is therefor different from place to place. Most of the time the power company will dictate the restrictions. You also need to wire over size since the start current (for the first seconds) is 5-8 times the regime current. And if no regulations apply you neighbor's lights may go out, hen you start the motor up.
Plenty of room here
Re: DOL Starter Question
04/29/2010 2:06 PM
Tell your management to hire a good electrical engineer. A lot of engineers are jobless!
Register to Reply Off Topic (Score 20)
India - Member - design engineer Engineering Fields - Electrical Engineering - New Member United Arab Emirates - Member - New Member
05/01/2010 7:33 AM
bcoz of large starting current(5-8 times), starting torque
(2x),etc.............it will screw ur cables , protective devices and the motor itself........
shamith gambhir, electrical engineer
Register to Reply 4 comments
Anonymous Poster (1); dvmdsc (1); SHAMITHGAMBHIR1 (1); Tornado (1)
