Previous in Forum: About "Namur"   Next in Forum: 8051 microcontroller proramming kit
Level Switch
04/29/2010 6:37 AM
What type of cable shall be used to connect the NO, NC, Common terminals in level switch to the motor (load). I am going to use the signal from Level switch to on-off the motor, through 24 V Dc relay.
Good Answers: 53
Re: Level switch
04/29/2010 7:03 AM
Any wire that can withstand relay coil current will do the job, however any statutory or regulatory requirement can super-seed my statement.
Good Answers: 29
Re: Level Switch
04/29/2010 8:15 AM
Any conductor capable of carrying the amperage of the load and conforming to local regs and process environment. Also, I wouldn't operate the motor directly from the relay contacts but rather use them to operate another control device such as a motor contactor.
Re: Level Switch
04/29/2010 8:28 AM
yes sir, you are wright. I am going to activate motor contactor through level switch. The contacor rating is 24 V dc. Shall I use twisted pair signal cable, what we use for analog signals (4-20 mA).?
Re: Level Switch
04/30/2010 3:08 AM
Follow the advice above.
Twisted pair would do it, though it is unneccessarily highly specified for an extra-low-voltage relay switching application. If it is the only cable to hand then so be it.
Register to Reply 4 comments
PWSlack (1); rakesh_semwal (1); ravindran_52k3 (1); RDGRNR (1)
