Previous in Forum: PCV pipe extrution   Next in Forum: Tank Bottom Eccentric ball valve
8 comments
Where Can I Find a Female Hexagonal Plug?
04/29/2010 7:40 AM
Hi ,
if any one can suggest the availability of the below item
Female Hexagonal Plug 3/8" bsp threaded , BRONZE ,NF E 29-801 EN 10242
THANK YOU
..."The truth is that there is nothing noble in being superior to somebody else. The only real nobility is in being superior to your former self...”
Re: Where Can I Find a Female Hexagonal Plug?
04/29/2010 11:42 AM
The more usual term for this is a pipe cap. A pipe fittings or hydraulics supplier would be the natural source.
04/29/2010 2:07 PM
Interesting...
When I read "Female Hexagonal Plug 3/8" bsp threaded" I think of a hex-drive plug, thus:
I was sort of ??? by the phrasing. EN 10242 is not a standard for brass or bronze fittings, I think. Perhaps a cap is correct.
I use these in NPT, but have no idea where to get one BSP.
Never bothered to check the difference in NPT and BSP. Will they interchange? If so, and this is the correct type of item, I have a lead for original poster (if brass is acceptable).
04/29/2010 4:53 PM
You might be right; the description can be read in more than one way. Hoping for clarification....
Good Answers: 27
04/29/2010 11:04 PM
I'm with Tornado on this one. For me Female plug is an oxymoron.
I think OP is referring to a cap as depicted in the bottom picture.
I have no special talent. I am only passionately curious. Albert E
04/30/2010 12:13 AM
So far I have found NPT (National Pipe Thread) pipe caps (female threads) in brass, with an outer hex profile; and hex socket plugs (male threads). No luck yet with BSP and bronze. Both are in McMaster-Carr Catalog 116 (Web-searchable).
05/01/2010 6:44 AM
Female dictates threads on the inside of the item.
Thus cap, as Tornado said. Kaisan has supplied the correct picture.
That is, if the OP did a proper job of defining the item in the first place. Which is always a crap shoot.
06/30/2010 12:01 AM
BSP= British Standard Pipe check this page out, may help? http://hisg.50webs.com/Basics5/basics5.htm
What if...
06/30/2010 12:02 AM
As far as a vendor for the part. As mentioned above, McMaster Carr, or Grainger, or Fastenal???
What if...
Register to Reply 8 comments
Doorman (1); Kaisan (1); lyn (1); Tornado (3); Whatif (2)
