Previous in Forum: Metal Detector   Next in Forum: Chinese 600 MW Dongfang Steam Turbine
9 comments
Color on Anodizing
04/29/2010 7:45 PM
Hi all,
At aluminum anodizing process, what are the different chemicals I need to use to get the different colors (red, blue, green, etc)?
The only reason to stay and keep alive its keep getting better........- Wilf
Re: Color on Anodizing
04/29/2010 8:03 PM
They use dye. I think. Google "color anodizing".
04/30/2010 10:56 PM
There are specific FDA, CE approved dyes from various manufacturers. http://www.platingsales.com/anodizingkits.html http://www.organicdye.com/anodizing.asp http://www.caswellplating.com/kits/anodizedye.htm http://www.metadye.com/
bioramani
04/30/2010 11:04 PM
Anodizing is an electrochemical process that thickens and toughens the naturally occurring protective oxide. It's an electrochemical process where the aluminum on the surface is converted to aluminum oxide. Due to its permeable nature, sulfuric acid anodizing is excellent for color dyeing and provides a base for primers, bonding agents and organic coatings. Sulfuric anodizing provides corrosion resistance and is very durable. The result of normal sulfuric anodizing is a thin coating of aluminum oxide on the surface of the original aluminum The freshly anodized part is immersed in a liquid solution that contains dissolved dye. The porous anodic coating absorbs the dye. The intensity of color is related to the thickness of the anodic film, the dye concentration, immersion time and temperature, among other things. There are numerous sources for obtaining colour dyes. You may refer US source http://www.reliantaluminumproducts.com.
05/01/2010 6:40 AM
Aluminium anodizing is a two-part process. The first step is the artificial growing of a relatively thick oxide-layer in sulfuric acid. After this first step the surface is still open, porous on a micro-level, allowing for the application of almost any dye consisting of small enough particles to enter the porosity. First rinse the surface very thoroughly with a low pressure jet of lukewarm water to remove any remaining acid and dry it with warm (not hot) air. Avoid touching the surface as much as possible, at least with hard objects. Next I used to make drawings/paintings with solvent-based felt-markers in any available color. Finally the surface has to be sealed, which is usually done by immersion in hot steam (at least 140ºC) for 10-30 minutes. The dye will be sealed inside the oxide layer, but exposure to UV-light will still affect it. For long lasting outdoor use I'd recommend industrial dying stuff (I used to use Sandoz' Sanodal), although some colours will still faint or bleach in time. You can also apply any dye through silkscreen printing, e.g. to tranfer photographic images. Great possibilities for artistic applications, but rarely employed.
Don't worry, be happy.
Good Answers: 117
05/01/2010 10:00 AM
Good Answer
Thank you.
Good Answers: 19
05/01/2010 12:04 PM
A word of caution with anodizing, if the part is subject to stress anodizing can lead to cracking and early structural failure. I've heard of a NTSB finding that noted a homebuilt helicopter crash caused by an anodized part failing prematurely.
05/01/2010 1:15 PM
Of course, the process control of any quality surface treatment need extreme caution and good knowledge of process chemistry.
No aviation component can be processed unless the plant is approved by civil/military aviation agencies.It require pain taking control of process by authorised and qualified personal. Aviation industry owe its enviable safety record because of this factor.
Insistence on ISO 9000 accreditation is the step in the right direction to make world more safe.
Failure of the anodized component may be due to fabricator not adhering to process control.
05/02/2010 4:11 PM
Good info here, but why not go to the people in the business ?
Check www.pfonline.com. They have a suppliers section, articles on various methods, and forums for discussion. They make their living doing this.
I'm always amazed that folks don't start with suppliers who are usually quite willing to share their knowlege even when not able to make a sale.
05/03/2010 8:24 AM
Take a look at this web site. There is a lot of great informatiom there.
I think you can get all necessary materials as well.
http://www.focuser.com/anodize.html
Good luck
Pacesetter
Register to Reply 9 comments
bioramani (1); fredart (1); krishnan.ng (2); lyn (1); Not too Smart (1); Ried (1); Yusef1 (1)
