Previous in Forum: Antimicrobial Substrates - Rubber   Next in Forum: Foam Agent Effect
Phospho Gypsum Granulation
04/29/2010 11:39 PM
We have Phospho gypsum (Calcium sulphate dihydrate) which is the byproduct of our phosphoric acid plant. This has got 15 to 20% free moisture.
Q1: Any economic or standard drying process & equipment to dry at the feed rate of 10 to 15 tph to achieve about 5 to 10% moisture.
Q2: Any gypsum granulating process?
Q3:Material handling equipment for Gypsum and MOC.
kindly advice.
Re: Phospho Gypsum Granulation
04/30/2010 11:35 AM
What are you doing with the gypsum now?
A simple drum dryer is an obvious choice. With rubber inserts or chains to prevent agglomeration on the internal walls. It should act as a granulator as well.
I have in my mind's eye a super phosphate dryer/granulator.
05/02/2010 11:51 PM
Dear Sir,
Currently we are sun drying to about 10 to 15% moisture content and bagging to sell for cement industry.
On trial we have taken in dryer of capacity 7.5tph at 15 to 20% moisture content at inlet (mixing with dolomite) and drying air flow rate of about 10000 m3/hr at 300 deg C with dryer outlet 65 deg C, but found heavy build-up dryer and material becomes powdery too.
regards,
SNA
09/17/2010 9:22 AM
Please advice me of the vendor for bagging machine you are use it, or you made it manually?
Anonymous Poster (1); morrie (1); tarek_10 (1)
