Previous in Forum: 8051 microcontroller proramming kit   Next in Forum: signal & control cables
low lub oil pressure testing on wartsila 9l20
05/01/2010 7:22 AM
gents,
how can I test the low lub oil pressure esm shutdown on wartsila 9L20 engine?
Re: low lub oil pressure testing on wartsila 9l20
05/01/2010 11:16 AM
With the engine running isolate the pressure switch or transmitter, bleed it down or release the pressure, if your engine does not trip then your ESD trip is not functioning, it may have been bypassed by someone before you, if the engine does trip great, put the sensor back in service then hide from the operators.
Seriously, the best time to do this would be during a period of down-time for the equipment in that way you can test at your leisure without interrupting operations.
Reply to Forum Thread
