Previous in Forum: low lub oil pressure testing on wartsila 9l20   Next in Forum: Current and Voltage Display in DCS
signal & control cables
05/01/2010 8:32 AM
What is the difference between Instrument signal,power & control cable. I want to know the difference with an example.
Re: signal & control cables
05/01/2010 10:15 AM
Homework ????
05/01/2010 2:24 PM
In the refrigeration plant where I work, we have power cables going to the large loads such as compressors and heaters (3-phase, 480 or 208 VAC). There are many solenoid valves, which are small loads of about 0.6 A (single phase 120 VAC); the wiring to them would be considered control wiring. It is just like power wiring, only smaller. Various meters that we have are connected to transducers (sensors) by signal cable, which carries low voltage and current, and may be twisted-pair, shielded, or coaxial, depending the type of signal. The signal wiring is segregated from the other types (in separate conduits if actually enclosed in conduits).
05/04/2010 3:34 AM
Follow the Cabling Standards in use at the installation.
Register to Reply 3 comments
Anonymous Poster (1); PWSlack (1); Tornado (1)
