Previous in Forum: Calculation of Magnetic Field Strength for Alternator Exciter Coils   Next in Forum: Building Automation System
Wattage for Speakers/Output of Receiver.
05/01/2010 1:22 PM
Hi, What I'm wondering is should the wattage of the speakers to my truck radio/CD player be twice the rms wattage of the speakers to be on the safe side, connected to the receiver?
Re: Wattage for speakers/ output of receiver
05/01/2010 1:54 PM
Actually the counter-intuitive audio rule of thumb is to have your amplifier/receiver to be capable of just a little bit more power than what your speakers are rated for. The most common damage that happens to a speaker occurs when an underpowered amplifier clips (tries to produce more power than it is capable) and a sudden DC voltage exists across the terminals of the speaker. While many woofers can handle this, a tweeter will be thrown hard its full but short excursion and the voice coil gets damaged.
5
Good Answers: 141
05/01/2010 3:42 PM
Redfred, As X -designer and manufacturer and repair facility for JBL. Klipsch, B&W, Altec, I agree: what you say is right.
More speakers are damaged, and specifically burnt in the speaker coil winding by amplifiers that are too light and start to clip.
Here a heat snow ball effect develops:
Normally a speaker has a rated impedance, let's say 4 or 8 ohms.
For car speakers 4 ohms or even lower is most common because the power voltage is only 12 volts. For higher power "freak systems" a higher voltage is generated to feed the amplifier.
This impedance of the speakeris commonly know as by 1000 Hz test condition. When an amplifier clips = or is forced to deliver more than it can provide, especially the low tones heat up the voice coil.
If there is no clean signal available, the amplifier "sees more a resistance, close to the copper wire resistance, which can be as low as 0.8 ohms for a powerful 4 ohm rated speaker. Result: the amp wants to give more power, clips more, the coil gets hotter and ... your speaker starts to sound like a spring loaded coil - because the glue of the voice coil fails and...
with some luck you have output fuses in the amp that blow, otherwise...
say goodbye to the end stages of your amp too. I rather GO FOR A HIGHER POWER AMP on a LOWER POWER SPEAKER than the seller's VICE VERSA myth.
Once your bass speakers start producing "square carton" sounds your amp is clipping.
When a bass guitar and a big drum sounds like a beaten bag
Be also aware of our sound detection ear hairs system. They vibrate on different frequencies and once over- bass'ed - hairs gone - nothing comes back - you become selectively deaf.
This however happens first in the MID TONES, because the lowest bass tones are more experienced as a VIBRATION instead of as a sound. LET YOUR MUSIC SOUND NATURAL - your car parts do not need to vibrate through the streets. You should become deaf from S*X too, but that is an other story.
Definitely a GA from me.
Plenty of room here
05/01/2010 4:57 PM
Did you know Fancher Murray?
Good Answers: 141
05/01/2010 9:58 PM
Not really, but the Platters told me about him, during our tour in Germany, now 26 years ago.
Plenty of room here
05/02/2010 7:21 PM
[quote]
...a sudden DC voltage exists across the terminals of the speaker. While many woofers can handle this, a tweeter will be thrown hard its full but short excursion and the voice coil gets damaged.
[quote]
could an active cross-over prevent (or at least mitigate) this?
05/02/2010 8:27 PM
The short answer is another confusing counter-intuitive yes/no answer. By using an active filter between a signal source and the power amplifier, you will make it less likely that the high frequency power amplifier will clip. For the low frequency energy will not be part of the total power provided by this amplifier. However, clipping an underpowered amplifier can still happen. This is why speaker manufacturers that build bi-wired speakers that can be used in active filtered systems will typically include a crossover network to still attenuate low frequency signals that go directly to the mid-range and tweeters. A saving grace that people get away with using an underpowered amplifier for the high frequency driver is that the human ear is more sensitive to the middle to high frequency signals. (Well except for many middle aged men who start to loose their high frequency hearing.) So even though most of the sonic information resides here, it is of a much lower power level for the same perceived loudness of the low frequencies.
Hence my answer of yes/no.
Register to Reply 6 comments
Anonymous Poster (1); dvmdsc (2); lyn (1); redfred (2)
You might be interested in: Speakers, Radio Receiver ICs, Optical Storage Media
