I am trying to size some bussing for some new switchgear.
I have (4) 2500 kVA .8pf 480V solidly grounded Y connected generators with .14pu x''d. The swgr is really close to the generators and have already determined that 200kAIC gear is needed. My question lies here...
Q1 - I haven't seen a circuit breaker larger than 6000A's do they make larger ones? If so do I use relaying with large (8000A) CT's and a heavy duty fast switch?
Q2 - Since the generators can put out a combined 12000A's and I want to be able to fully utilize it all the power from them can switchgear be rated that high? Would you put a tie breaker to split them? can the bus be tapered? I cant be the first to do this
