Previous in Forum: UPS & Invertor   Next in Forum: High Efficiency Motors - Is there a paradox?
Selector Switch
05/02/2010 2:24 AM
Thou it is silly Question But i am little bit confuse
Can anybody tell me what is the basic fuction of Selector Switch & where it is used in the controlling ckt. Thanks
Re: Selector Switch
05/02/2010 3:08 AM
A simple switch just closes or opens an electrical circuit (in other words, turns it on or off).
A selector switch can also be as simple as that, or can offer more options. The most common example might be a "Hand-Off-Auto" (3-position) switch. The "Hand" position will typically bypass various controllers and feed the controlled item directly. The "Off" position interrupts power to the controlled item. The "Auto" position sends power through a further device such as a pressure/flow/temperature switch that then cycles the controlled item automatically.
There are many variations to this basic idea. The more complex ones may be called "cam switches" or "drum switches." They can turn or off virtually any combination of controlled devices.
When a selector switch is moved to a position, it maintains that state until moved again. In contrast, a push-button opens or closes a contact momentarily.
India - Member - design engineer Engineering Fields - Electrical Engineering - New Member United Arab Emirates - Member - New Member
Re: Selector Switch
05/02/2010 3:31 AM
as the name itself suggests it a switch for selecting mode of operation......it can be hand mode or auto mode or zero(off) mode( 3 way ss)........2 way SS (ON-0FF)...4 way SS, 6 way SS etc......they r used in switchgears, automation , synchronisation,etc..most electrical installation..........
shamith gambhir, electrical engineer
You might be interested in: Bit Error Rate Testers, Switch Boots
