Previous in Forum: Corona   Next in Forum: MCCB Ith & Ir Acronym Meaning
Kirchof Law
05/02/2010 4:57 AM
Is kirchof law applicable for AC and DC....?
Pathfinder Tags: kirchof law
Re: kirchof law
05/02/2010 5:08 AM
Yes it is applicable for both ac & dc....
There are no shortcuts on the road to a great experience.
Re: kirchof law
05/02/2010 9:11 AM
It's Kirchoff with a capital K and two f's.
India - Member - New Member Engineering Fields - Electrical Engineering - New Member
Re: kirchof law
05/02/2010 12:19 PM
Friend i also attended NTPC kcl kvl are applicable for both ac n dc what more questions you got doubt? I also want to clarify more.
Re: Kirchof Law
07/21/2011 4:24 PM
Kirchhoff law is applied to AC & DC circuits provided that they have a relation as Current in the circuit is proportional to applied voltage.
That is V=Z*I; Where V is applied Voltage in volts to the circuit I is current in the circuit Z is a constant and is known as Impedance in AC circuit has its unit as Ohms if the circuit is DC then it is known as Resistance and also has it units in Ohms.
They are many circuits that they do not follow this relation specially in communication circuits and power Electronic circuits.
For example circuit having the Zenor diode or AC circuit having inductance with iron core, in witch Flux density is maintained as long as below 1.6(Kirchhoff law applied) and flux density above 1.6 kirchhoff law does not applied due to non linearity or saturation in iron core.
B.E, M.I.E, M.S
Register to Reply 4 comments
Aseer (1); hithuanand (1); lyn (1); Mushtaq Hussainh (1)
