Hey guys,
On one of our compressors, the seal oil level at the reservoir is increasing gradually by 1% each hour, while we are loosing a much smaller amount of lube oil in its reservoir. We had to transfer oil from seal to lube reservoirs couple of times to clear the high level alarm.
what is the cause of this?
I thought about the lube oil is escaping into seal oil drains, but the seal oil pressure is much higher than the lube oil pressure. and we have between those two a wind back seal, which will drain any oil passes through.
P.S; we just overhauled the machine.
Thank you
