Previous in Forum: What is Milk?   Next in Forum: Melting an Aluminum Crankshaft
9 comments
Nigeria - Member -  Member
Time Set on New Wall Clocks
05/05/2010 5:08 PM
This morning in our local TV station, viewers were shown round the stores of some Wall clock resellers in select local markets. The time set on all the new wall clocks was Ten minutes past Ten O'clock.
The anchor lady then asked "how come all the new wall clocks had thier time set at Ten past Ten O'clock"
None of the responders seemed to know why and all the resellers interviewed indicated that the Wall clocks were imported that way.
Indeed, I don't know why and thought to raise it in this forum as I am positive someone in this forum could know.
So, over to you all.
cheers,
ethobil
Join us to make the world a better place: Propergate peace.
Re: Time Set on New Wall Clocks
05/05/2010 5:30 PM
It is a marketing technique, the same applies to wrist watches on a magazine ad; first of all, that position of the pointers allows full view of the brand name, which is usually located under 12 o'clock, and secondly, it is more eye catching for clients some simetry on a brand new clock.
Yahlasit
05/05/2010 5:35 PM
I have been told it is to honor the 16th president of the United States, Abraham Lincoln, who was shot at around 10:10 PM. This was sufficient to satisfy the curiosity of a nine year old boy, and I never questioned it.
Why would time keepers around the world hold such a custom? As I consider, there is sort of a disconnect there. Maybe my Gramma told me a fib, just to keep me quiet.
I checked the ROLEX™ website, to see if they have a bit of history. No info about why, but every watch displayed on their website is set to 10:12 or pretty close to it. There must be a global reason for this custom.
05/05/2010 6:03 PM
That one to honour Abraham Lincoln, my kids will here it as well
cheers,
ethobil
05/05/2010 5:37 PM
The "guest" is correct based on a radio discussion that I recently heard where a marketing guru was being interviewed. He also remarked that the position in some way "looks like a smile" and was selected for that.
He indicated that there is a move with some advertisers to change the time displayed to 11 minutes to 2 as this situation creates an "expectation" of the minute hand to move.
From my perspective, I buy a watch or clock when I need a new one. Advertising like that would not influence my decision, especially when they all have chosen to use exactly the same style.
05/05/2010 5:56 PM
The answer from the guest looks like it and you'd confirmed, thank you for the effort.
cheers,
ethobil
05/08/2010 8:27 AM
While the guest's answer sounds plausible it doesn't mean that it's actually correct. And just because someone else supported his response also doesn't make it a correct answer as both may have gotten their positions from the same source which could be in error. Or that may be no actual way to confirm the reason why. I am not saying it's not a marketing gimmick....it very well could be....just that I'm not sure the answers given are enough.
If it is a marketing gimmick, I wonder if some marketeer reasoned it out...or if actual studies were done (i.e. show a few hundred subjects watches with different hand configurations and see which one the subjects find most appealing or something along those lines).
J B
05/10/2010 12:49 PM
"While the guest's answer sounds plausible it doesn't mean that it's actually correct. And just because someone else supported his response also doesn't make it a correct answer as both may have gotten their positions from the same source which could be in error..."
While agreeing with your assertion, note that the guest's response was direct and clear and not pointing to mythology. Indeed of all the response to this question both in and outside this forum (see my OP) the guest's has been more pragmatic.
"...I am not saying it's not a marketing gimmick....it very well could be....just that I'm not sure the answers given are enough..."
The guest indicated that it was a marketing technique and not gimmick.
Cheers,
ethobil
Good Answers: 25
05/10/2010 11:51 AM
During the digital watch phase were they all set to 10:10?
Goodness has nothing to do with it.
05/10/2010 12:52 PM
No idea
cheers,
ethobil
Register to Reply 9 comments
Anonymous Poster (1); beriberi (1); Doorman (1); ethobil (4); JBTardis (1); Just an Engineer (1)
You might be interested in: IC Clocks, Time and Frequency Standards
