Previous in Forum: Time Set on New Wall Clocks   Next in Forum: Radar Unit vs GPS: Which Speed is More Accurate?
Melting an Aluminum Crankshaft
05/05/2010 6:36 PM
I would like to know how to melt a crank (aluminum), which need materials, the necessary recommendations to quit a good job. thanks beforehand
eh already asked several times perocuadno want to see the answers, I look and look at all but can not find globs of way that I could help
Re: Melting an Aluminum Crankshaft
05/05/2010 6:59 PM
Good Answers: 74
05/06/2010 11:32 PM
If incoherence could melt, you would be standing in a pool of aluminum.
The Twain Has Met
Good Answers: 18
05/06/2010 11:51 PM
Melting. schmeltimg.
Want to quit your job? Slop some mercury paste on a section of the crank and wait. The mercury will eat away the aluminum, make it spongey and weak, and will prevent a protective aluminum oxide layer from forming. Eventually, the crank will just break while in use.
Allied saboteurs used to do this on German planesin WW-II. They'd wipe mercury-containing paste on wings and landing gear, and the thing would eventually break off.
Quite neat! The damage wasn't readily visible until it was too late.
Cheers! DZ
Do unto others. Then run.
Good Answers: 60
09/02/2010 8:36 AM
Register to Reply 4 comments
DreadZontar (1); ky (1); lyn (1); peterg7lyq (1)
