Previous in Forum: Melting an Aluminum Crankshaft   Next in Forum: Vibration Technology Data
80 comments
Radar Unit vs GPS: Which Speed is More Accurate?
05/05/2010 6:58 PM
I have been presented with the following conflicting evidence in a speeding case and would like to make the right ruling and also sound fairly intelligent if possible. No accident involved. At stake, besides justice is only the amount of the fine.
A duly calibrated 'Applied Concepts Dual Stalker' radar unit, used by an experienced Officer with no apparent outside interference, and registered the speed at 105 mph, versus 'The Street Pilot 111' GPS unit by Garmin which purports to show that the highest speed attained by the vehicle that day was 96.4 mph. In simple terms if possible which is the more accurate and reliable and why? Thanks.
Re: Tech wars.
05/05/2010 7:08 PM
That's interesting. My reaction is go with the Stalker. It's within sight of the vehicle. And certified.
From Garmin:
"Garmin® GPS receivers are accurate to within 15 meters on average."
From Wiki:
"One of the most significant error sources is the GPS receiver's clock." I'll leave verification of the facts up to you. Under ideal conditions GPS can get you close.
Not to mention that the signal travels up to the satellite and back to earth.
105 MPH, Your Honor.
Re: Tech wars.
05/05/2010 7:28 PM
Thanks. You have given me 2 things to research, the GPS receiver's clock and the Garmin site to see how they rate their unit's speed reading accuracy.
Re: Tech wars.
05/05/2010 7:37 PM
Excuse my manners. Welcome to CR4. Thanks for registering. We're a diverse lot with a healthy cross section of intelligence and experience.
You should stick around, we need legal opinions sometimes.
I give legal opinions freely without any formal training at all, so at least you know the "lingo".
Good Luck in your quest for truth and justice. 105 mph!
Re: Tech wars.
05/07/2010 10:15 AM
"Not to mention that the signal travels up to the satellite and back to earth."
Unless I'm badly mistaken, GPS receivers are just that: receivers. They send no signals to the satellites. The only signals they send are over wires to their own display or to connected computers. There are probably some GPS devices that connect to computers via one or another form of radio signal such as Bluetooth, but such transmissions would have no effect on the precision of position measurements or other values based on the position measurements, like velocity.
Even with the elimination of that possible source of error, the radar gun remains the more accurate system.
Re: Tech wars.
05/07/2010 11:30 PM
Then how do the satellites know Which receiver is where? There must be some form of information request or tracking signal from the receiver for the satellites to respond to. Some type of electronic identifier. (like beep find me, beep find me, beep find me, you are here, no here, no here.) After all, this is still some form of signal triangulation.
In reply to #59
Re: Tech wars.
05/08/2010 12:52 AM
The satellites DON'T know anything whatsoever about the receivers.
If you get your strongest signal from KOA Denver by pointing your antenna directly East, and you get your strongest signal from KOB Albuquerque by pointing your antenna directly South, then you must be somewhere near Wolcott, Colorado. Neither KOA nor KOB have any idea whether you were listening to their signals or not. That is a very simple example of signal triangulation.
Hopefully someone who knows a lot more than I about the GPS signals will jump in and clarify this, but the satellites constantly transmit information related to time and the satellite's location. It is up to the GPS receiver to acquire information from several satellites, and use that information to calculate position. Once it calculates two positions, it can then use the elapsed time to calculate a velocity. No signals need be sent from the receiver to the satellites.
Re: Tech wars.
05/08/2010 2:03 AM
GA. I am amazed at how many posters to this thread think that their anecdotal tales would constitute good evidence of anything. For instance, it is conceivable that at time t1 you could be about to enter a hairpin turn, and at time t2 you had recently exited the same turn. You might have traveled say 500m road distance in a minute, but the two positions might be only 50m apart. This would compute to a speed of only 0.1 times your real average speed. And that's assuming the two locations were accurately determined in the first place, which we know is not necessarily true.
Even if the GPS were 0.9999 accurate, for any two points on a curve, it would under-report your speed. It is distressing that some engineering thread responders can be so gullible. But then we get the over-unity stuff as well.
Good Answers: 32
Re: Tech wars.
05/08/2010 1:29 PM
Tornado,
I don't mean to offend, but I could not let the errors in logic go.
I assume by anecdotes you mean the observations that several folks have made that their GPS indicated speed correlates very closely with speedometer readings.
True, this anecdotal evidence, as this is just observed, not recorded. Also, the accuracy and precision of the speedometer etc. is not verified.
But the average GPS owner has made hundreds if not thousands of observations correlating GPS indicated speed with speedometer readings in real world conditions.
Your example would be correct if GPS only updated once/minute. Typical GPS systems up date at least once/second if not many times per second. You also assume that GPS relies only on time and position. Many GPS systems use the doppler effect to determine velocity.
Both radar guns and GPS underestimate velocity when attempting to measure speed through a curve.
So who is more gullible? The person who believes anecdotal GPS evidence based on thousands of real world observations, or the person who believes your example which has no basis in reality?
In reply to #65
Re: Tech wars.
05/09/2010 3:04 AM
I chose a fairly extreme and artificial example in the hope it might highlight that aspect in an easily understood way.
I am curious to know how Doppler figures into GPS operation. So far as I know, the GPS does not bounce signals off of any objects in the direction of travel, and then compare the Δ frequency of the transmitted and returned signals. I could be wrong.
You say that the GPS updates about every second. But I understand Garmin claims 15-foot precision. 15 fps ≈ 10.2 mph. That's not too inspiring.
If defendant's counsel can find more convincing testimony, then so be it. Wanna volunteer?
Good Answers: 918
In reply to #68
Re: Tech wars.
05/09/2010 7:28 AM
The only doppler effect is the movement of the GPS satellite through its orbit. As the satellite passes over head the distance between the receiver and the satellite are changing.
Picture a receiver sitting on the Earth's surface and a satellite in a circular orbit over head. The radius of the orbit is the center of the Earth's mass, but the receiver is off-center, so the distance between satellites and receiver is always changing, which introduces a doppler effect.
In reply to #70
Re: GPS & Doppler
05/09/2010 9:27 AM
The Doppler effect you describe will shift the frequency of the carrier signals coming from the satellites, and the receivers must have sufficient bandwidth to accommodate those shifts, but it will not affect the digital time values or any other digital information encoded on those carriers.
There will indeed be additional Doppler shifts due to the motion of the GPS receiver, but they will be small compared to those caused by the satellites' approaching and receding. It would be a very complex process to calculate the velocity of the receiver from those shifts.
Good Answers: 918
In reply to #71
Re: GPS & Doppler
05/09/2010 10:17 AM
The doppler shift is used as part of the Pseudo-Range Rate (PRR) calculation, so it would impact accuracy as well as impact receiver frequency.
The SVs are moving at 7 km/s and the Earth rotates as much as 400 m/s (depending on you location near the equator. Vehicle speed is negligible, as you noted.
GPS receivers also look at the phase of the 1.023 Mb/s C/A code and the 1575.42 MHz carrier as part of their PVT (Position Velocity Time) calculations.
As I said, the whole thing is very complex and I am a little rusty on some of it, but I do know that it is not a simple process and contains more detail than one would ever think.
Good Answers: 918
In reply to #59
Re: Tech wars.
05/08/2010 8:42 AM
A GPS receiver is just that, a receiver. It does not transmit any data to anything.
Each GPS satellite contains its own set of atomic clocks (one or two Cesium and two Rubidium clocks depending on the version of the GPS satellite). All clocks are synchronized with each other and synchronized to each other satellite and they are all compensated for relativistic and gravity induced time dilation (each has an opposite effect in the way time is either sped up or slowed down). Yes, they are that picky!
The GPS satellites (hear after called SV for space vehicle) broadcast their atomic clock time stamps in a wide beam that covers the whole Earth's globe (geoid (WG84)). The SVs are in a lower Earth orbit (each takes 11 hours and 58 minutes for one orbit), so they are not geosynchronous with the exception of a few special SVs that are called SBAS that support WAAS (Wide Area Augmentation Satellites) used mostly by aviation receivers to gain further accuracy.
About 30 GPS SVs orbit the geoid. Their orbits are varied and go in polar, equatorial, and orbits in between. Each broadcast their time stamped clocks to Earth. They actually broadcast them on two different frequencies (one for civilian use and one for military). Both are encrypted to prevent what as known as "spoofing" or jamming of the signals. The military can and will turn off the civilian transmissions if they deem a national emergency exist (all out state of war, etc.).
The US also sends correction data to the SVs to account for minute changes in orbit and ionospheric changes in the atmosphere. That data is rebroadcast to GPS receivers for improved accuracy.
Now, the meat of the subject. When you turn on your GPS receiver it attempts to locate as many SVs as it can find. It orders or ranks the found SVs by signal strength and discards any that are disabled (it happens), too low on the horizon, or too weak in signal strength. Your receiver compares the atomic clock time stamps with each other to get a "triangulated" (is usually many more than just three SVs) position based on the time stamped data sent by all "good" SVs.
The receiver actually does a lot more complex things inside, like detection and filtering of multipath signals (signals reflected from buildings, etc.), doppler effects of the SVs, calculated signal length paths for each SV transmission, ionospheric refraction corrections, and calculating the true GPS time based on the aggregate of the SVs' time stamps. The receiver will also do some sanity checking of each SV for overt errors and remove them from the active list. For instance, if the time stamp suddenly jumps and indicates a sudden change of distance that exceeds the probability of such a jump, then that SV is flagged as bad.
Are you still with me? There is a lot more to it and I probably have given you more than you wanted to read. This is an extremely complex subject as you may start to realize. ;-)
In reply to #63
Re: Tech wars.
05/08/2010 10:18 AM
Sounds like those SV's and the receiver are as busy as a one armed paper hanger. With present day technology the whole operation isn't too daunting a task. Understanding the entire process is.
We know that both devices are capable of presenting precise data, both are equally capable of fulfilling the equation "garbage in = garbage out". I think that an expert witness could make a valid case for either one being the more accurate, given all the standard disclaimers.
I do hope the study and application of law relative to DNA was a lot more conclusive than what we are seeing here.
If you fail to follow through, you will fail.
Re: Radar Unit vs GPS: Which Speed is More Accurate?
05/05/2010 7:42 PM
I would be curious to know how often the GPS is updated. There must be two separate position readings, with some amount of time between. Thus the GPS is computing only an average, not an instantaneous, velocity--apparently subject to as much as a 15-meter uncertainty in position each time. The radar's principle (Doppler)is different; it does give instantaneous velocity, within its limits of accuracy.
I too would be more inclined to accept the radar reading.
9
Good Answers: 918
05/05/2010 10:15 PM
No contest.
Radar gun wins.
Radar gun accuracy < ±1 mph.
Even high accuracy WAAS GPS units used for aircraft have limits that are not that good. The best WAAS enabled GPS receivers will discriminate is about 3 meters. Your Garmin is < 15 meters.
Garman claims a .1 kt speed accuracy RMS, however, here is the big issue... That's the best it can be. GPS degradation can throw a huge dent into that accuracy and that is the rub.
The contest between radar and GPS will come down to which side can prove the least inaccuracy. Generally, police periodically calibrate their instruments and have training to minimize capture errors. A GPS user can't claim that and are at the mercy of the GPS constellation position, number of available satellites, spheric conditions, and multipath errors. It becomes impossible to prove the system accuracy at the time of use, so your defense goes out the window.
Unless you can provide a convincing argument that the officer did not correctly use the radar, you have a very hard case to prove. Additionally, it comes down to your word against the officers. The officers tend to have the upper hand in these situations.
If you want further research, look up the FAA GPS requirements and the methods employed for obtaining best accuracy. My last project was working with WAAS GPS and there a multitude of issues that can disturb GPS position accuracy. GPS clock rate is one of them, but there are bigger issues with signal propagation through the ionosphere and refraction that require special processing attention in the receiver.
Automotive receivers do not carry the same level of accuracy as aviation and therefore are more prone to position error.
Register to Reply Good Answer (Score 9)
05/07/2010 12:09 AM
I hate to be the one to throw in the monkey wrench but that is not exactly true. The unit is capable of that accuracy but there are several significant variables to consider. I had the same discussion with an officer who said that I was going over sixty in a residential zone, but what he actually tracked was the turning velocity of a large truck behind me. I asked him if he really wanted to go to court with a weapons radar/ Electronic warfare tech after I got a statement from the driver who was behind me. Law enforcement likes to publish best possible specs but if you dig into the information that spec is only under very well defined conditions. By the way the speed on the garmin is determined by rate of change of position so the instantaneous position is not really relevant.
The real issue is that the court is going to accept the radar gun before anything else and you are already guilty without expert witness to dispute the radar speed. You are going to pay the price either way.
Good Answers: 32
05/07/2010 10:33 AM
Sorry, but I have to disagree.
The manufacturer's specification for this particular model is an accuracy of 0.05 m/sec, or roughly +/- 0.1 mile/hour. I'm sure that this is under perfect conditions, but I'm also pretty confident the radar gun's stated accuracy is under ideal conditions as well.
Actual GPS readings vs. true speed studies indicate that such GPS velocity accuracy is realistic, also shown here.
So, if you go by device specifications, the GPS wins hands down, with 10X the accuracy of the radar.
Under real world conditions, GPS shows accuracy comparable to the radar guns specifications (specifications tend to be stated for ideal circumstances).
Both radar and GPS are prone to errors. It is impossible to determine which device had the most error at the time of the measurement.
So to answer the OP's original questions:
The GPS is more accurate under ideal conditions. It is also not prone to operator error, which the radar gun is. However, GPS does have it's own sources of potential error.
As to which is more reliable (accurate), there are just too many variables to know for sure.
Good Answers: 42
05/07/2010 10:56 AM
With my Garmin I have never found the large discrepancy that the OP posted.
05/07/2010 11:38 PM
How many times do you get pulled over?
Good Answers: 42
In reply to #60
05/09/2010 2:26 AM
I haven't been pulled over in 25 years!
Previous to that once about every 7 years.
(Yeah, chicken shit driver that tries to obey the posted limits! Saves $ and lives!)
05/05/2010 10:23 PM
While I would agree with the radar unit being the more accurate, there are some caveats:
1. Was the calibration on the radar unit still valid at the time of the infraction?
2. Was the officer properly calibrated (training up to date) at the time?
I mention this because a coworker (~30 years ago - he was a radar technician) beat a ticket that way. Not only that, but his lawyer who took the case pro bono (provided that he had his facts right), and negated quite a few other cases he was representing - including his own.
My advise (usually not worth reading), is to say OK, you have just proven/admitted that you were going 96.4 mph (still an offence), without setting a precedent that GPS is better than radar.
05/05/2010 10:34 PM
"~30 years ago" Is he available to testify? Or, dead?
Register to Reply Off Topic (Score 20)
05/05/2010 10:57 PM
Not sure. Lost touch when I left Oracle, Az. in 87, to go to work for an Engineering firm in Birmingham.
05/05/2010 11:00 PM
From a dry heat to a swamp?
05/06/2010 9:54 AM
And back again! Southern Nevada.
Good Answers: 918
05/06/2010 6:08 AM
Rereading the original post: "A duly calibrated 'Applied Concepts Dual Stalker' radar unit, used by an experienced Officer with no apparent outside interference."
Seems that the jig is up. ;-)
05/05/2010 11:08 PM
Why is this even an issue? What would be the difference in a fine between (let's say the speed limit was 70 mph) 26.4 or 35 MPH over the speed limit?
Would it make that much difference?
Anyway, I'm with the radar for accuracy, being a much more "local" system of measurement.
Good Answers: 918
05/06/2010 6:10 AM
Some states make it a felony for speeds of 100 mph and beyond. So it can be a BIG deal to the offender.
Good Answers: 53
05/05/2010 11:41 PM
In my experience GPS indicated speed is very accurate when tracking 8 or more satellites. Not so much around tall buildings, cliffs or in a tunnell. Also the max speed on the display can be reset in a second by the operator.
05/06/2010 1:41 AM
In my experience, my GPS receiver indicated speed always tracks within 1 mph of my car speedometer. And I have used the same GPS receiver in four of my vehicles, plus at least one, maybe more, rentals.
I don't know the update rate, but if I step on the gas or brake, the GPS indicated speed tracks with the speedometer.
I would say that if you were traveling at the higher speed long enough to be locked in by that radar gun, your GPS receiver should definitely have indicated that same speed, plus so should have your speedometer. If both your speedometer and GPS receiver indicate the same speed, that is a slam dunk that the radar is the outlier, and therefore questionable.
As others have pointed out, the GPS accuracy depends on signal strength and number of visible satellites. Somehow I can't imagine you were doing either 90 or 100 mph while tall buildings were blocking your view of the sky. If that were indeed the case, you would be an idiot and deserving of whatever they throw at you.
The real issue here is that even assuming your GPS and speedometer were both reading the speed you claim, how do you make that case in court?
emc_c
05/06/2010 8:31 AM
You should read the original post more carefully.
05/07/2010 12:08 AM
"I don't know the update rate, but if I step on the gas or brake, the GPS indicated speed tracks with the speedometer."
I've had the same result. When my speedometer reads 70, GPS says 72; speedometer 35, GPS 36. (I attribute to tire size and age of speedometer.) No deviation, even by +/-1 mph.
Dangerous Bill
05/06/2010 7:23 AM
It's makes no difference. You are guilty.
This topic would interest me if you got tagged during 75 mph in a 65 zone or something similar.
The fines probably max out at some point.
05/06/2010 11:30 AM
READ THE ORIGINAL POST, CAREFULLY!!!!!!!!!!!!!
The OP was not the speeder.
05/06/2010 9:42 AM
I don't think anyone can make a case that the gps is more accurate than the hand held device. I do think that the driver is captive to the instruments in his vehicle.
The op states that a felony is not involved in this case, only the fine. So nothing of real value is involved except the principle. If the op had said that an experienced officer had observed the vehicle speed and estimated that it was X mph, I personally would have found that statement to be more objective than quoting what some digital readout had indicated to the same officer. Neither electronic device is infallible.
Unless this is a German autobahn, the driver admits his guilt, why would you split hairs over the numbers involved. To his knowledge he was making X mph based on two instruments of questionable accuracy that seemed to agree. The officer probably only had the one instrument. I doubt if he had much empirical knowledge about vehichles traveling 105 mph, most folks don't get to see much of that on the local highways.
Good Answers: 918
05/06/2010 11:15 AM
While it's not stated in the original post what the difference in the fines would be, it is logical to assume that it must be significant.
If it was as petty as you suggest, then I don't think the question would have ever been posted.
Laws vary state to state, but, for example, in Virginia it's a fine of up to $2,500 and mandatory jail time once you cross 100 mph. They are the most strict that I know of when it comes to speeding.
05/06/2010 11:27 AM
Do we know yet whether this incident occured in the US before we start quessing which State has jusisdiction?
Looks like the OP has left the building.
People making all sorts of assumptions on motif now.
Good Answers: 918
05/06/2010 2:05 PM
No we don't, but I can only assume that there is a battle between >100 mph versus <100 mph, there probably is more to it than just a proportionally higher fine because the delta between the two numbers is simply not that great.
05/06/2010 2:28 PM
Key words:
No
But
Assume
more
probably
This is an engineering forum?? Good Lord help me.
Register to Reply Off Topic (Score 21)
Good Answers: 123
05/07/2010 7:31 AM
Here is another key word,
"Guest"
Bob
05/07/2010 7:33 AM
Moderator Action: Removed bad language.
Good Answers: 918
05/07/2010 8:34 AM
So in the absence of immutable facts, you can draw no conclusions?
Inference is not part of your engineering tool set?
How can you possibly solve problems without that?
05/06/2010 2:21 PM
Take a look at the grammar. No misspelled words and good sentence structure along with the reference to MPH leads me to believe that this person resides in the USA.
I wouldn't blame them for leaving. We do what we always do. Argue over details in an effort to prove our superior intelligence over each other. This generally assures that the OP is overwhelmed with useless information while we bicker among ourselves.
Please take this last comment constructively.
05/06/2010 2:39 PM
Just because OP didn't make numerous grammar and spelling errors does not make his query an interesting one. Or place him in the USA.
I find you are generally the first to argue, prove, and/or bicker.
Now that I think about it, the OP is likely the violator's Attorney looking for information to use at trial. But now I too am guilty of arguing, introducing facts not yet in evidence, badgering the witness, and on and on it goes...............
Register to Reply Off Topic (Score 24)
05/06/2010 12:32 PM
I guess that statement is open to interpretation. You are right about Virginia, Over 75 is considered reckless driving.
05/06/2010 4:20 PM
This is a first for me and quite enjoyable. Thanks to all of you for your input. The technical information and suggestions were/are most helpful, and even your gut reactions and other observations are of interest. As amusing as some of your exchanges were I didn't mean to start a mini firestorm (don't be too hard on them lyn) and I should have been clearer at the outset. As Hero succinctly stated and others surmised, a finding of a couple of mph either way can make a huge difference at these speeds. In California over 100 mph has a minimum fine of $776 versus $445 for 100 mph, no traffic school and 2 points on the record,(which is the same as for reckless driving and a definite insurance jump); a possible 30 day suspension. A second conviction in 3 years has a much >fine and mandatory suspension by the DMV. As to some of the other points: Besides the fact that I believe that everyone receive and hopefully feel they had a fair hearing, even if they lose, as noted by KilowattO, this Radar v. GPS case is important to local law enforcement and will be somewhat of a precedent, so the reasoning has to be as sound as possible. Finally, although I never assume that anyone is perjuring themselves, I want to ask Ace if he is sure that the display can be easily altered? Thanks again.
Good Answers: 918
05/06/2010 6:11 PM
I can't speak for the specific GPS system employed in the car, but on mine I can go into specific screen and reset all the trip data gathered to date.
What your next course of action should be is to look online or get the paper copy of the specific operator manual for the GPS system in the car. That manual will tell you exactly how the user can reset the "trip data", which includes the trip odometer, average speed, and maximum speed.
From there you can make a case for or against the probability of the operator performing the reset function to confound the reading of the radar gun.
This is still an uphill battle, but if opposing counsel does not pick apart your argument you may still win the day. GPS operation is still a mystery to most people and that may play in your favor. However, you sound like an astute lawyer and I am sure this is not the only arrow in your quiver.
Good luck with your case. It sounds like it will be interesting.
Good Answers: 42
05/06/2010 11:41 PM
My Garmin Nuvii routinely reads faster than my Speedometer by about 2 mph in a 2009 GMC F350, cruising in open country.
However, I have noticed on a level curve with cruise control set and engaged for 70mph the speedometer reads steady, but the Garmin will read 1 or 2 mph slower. I always figured it was the GPS measuring cords on the curve that were shorter than the path travelled.
About 35 years ago as a passenger in a Porsche, the driver got a ticket for about 15mph over in a 30mph zone. I was certain he was not speeding. As we sat in the cruiser with the Porsche ticking over behind us the radar was quite content to read 10 to 15 mph without another vehicle in site! To this day I think the driver got a bum rap.
05/07/2010 1:26 AM
I wish to advise that a Lidar unit is affected by many physical and weather phenomen and I have be the target of a zealous officer of the law. I was following another vehicle closely at the legal distance behind. I was clocked at 79 Kms/hr than the the mates car in front whose speed was supposedly clocked at 61 Kms/hr in a 60 Kms/hr zone. We had traveled in convoy for more than 80 kilometers and it did not ring true that such a speed variation could be for two vehicles that were traveling as though there was a tow rope between us. It depends on the officer behind the gun and I doubt there was a 2 second delay between us that the officer could have set and re-targeted my car. All I can say, is check the copious literature on just how in-accurate speed guns are away from the perfect conditions required to correctly calculate speeds. A famous court in California was shown that a 'Palm' tree in the court building was in fact doing 23mph.
Mechanical Solutions Company where 'There is no such thing as a PROBLEM, just an ISSUE requiring a SOLUTION'.
Good Answers: 62
05/09/2010 2:24 PM
Not to worry your Honor - we do this for fun.
Pigs in mud and engineers in arguments, as they say.
I work with high accuracy and high reliability GPS certified for flight and get asked regularly why someone's dash board model acquires satellites and provides position so much more quickly than my rather expensive ones.
Because there are no consequences for your dash board model being wrong.
So just a quick couple of technical details:
A. The radar gun is both more reliable, more accurate, and certified.
B. So as not to be a Luddite, if they wish to present contradictory evidence from on-board equipment, ask if they are willing to have the ABS downloaded. Also not certified, but an interesting third source of speed data and I would guess lots more accurate than the GPS. And ABS data HAS been used in evidence before.
C. In general...GPS is very good at locating you on the planet - everything after that depends on the machine that uses that data. It is actually quite difficult and expensive to make a good overland navigator that is moment-by-moment accurate. And they are not available for $499 at Best Buy.
But as others have said - glad to have you around!
You can 'splain to the rest of us the difference between law and justice ; )
05/06/2010 10:52 PM
Had the gps been reset the mileage would have read .1 miles. I do not know of being able to reset the max speed without resetting all the data.
05/06/2010 11:55 PM
There are requirements for calibration, certification and recertification of radar guns. There are no such requirements for onboard GPS units. The GPS could have been malfunctioning, its update rate might be to slow to see the brief peak to over 100 mph that the radar caught, etc.
Radar is admissible. Onboard GPS should not be, particularly because the onboard GPS is under the law violator's control: who can know how it might have been tampered with, and who knows if the maximum speed recorded by it was recorded at the time of the speeding offense? Who knows if the GPS was even turned on at the instant of the speeding offense? The maximum speed recorded by the GPS has no validity.
At very least, the evidence would have to be a strip chart plotted from GPS data, with each (second-by-second) data point date and time stamped. Very few GPS units have the capability to retain such data. But even then this would have to be a certified, calibrated GPS unit.
The guy was doing 105. No reasonable doubt that he was not.
05/07/2010 1:00 AM
The gun, just because the PIG* was holding it!
* Pride Integrity and Guts ...
05/07/2010 8:25 AM
Hi there, Guest,
Boy, that acronym takes me back about 25 years! Now I'll spend the rest of the day wondering why I ever left law enforcement, albeit it was only a small university department. I could've been retired and on a beach somewhere by now...
Logan
Sorry, all, forgot to mark this as 'off topic' and I don't see that capability in the Edit mode. Mea Culpa...
Good Answers: 18
05/07/2010 2:31 AM
This is a strange one. Th "right" ruling here seems an ambiguous statement. The last paragraph about the stalker seems a dead dead giveaway of a done deal. Why then bother about the accuracy? You have already decided that the officer is right, therefor his evidence is above question.
If you are a real legal person and you practice "fairness and apply benefit of the doubt principals" then by all means use the supplier's (Garmin) evidence rather than a forum which is by and large hearsay anyway.
Always learning
Good Answers: 18
05/07/2010 8:41 AM
Some interesting posts here today, but another thought comes to mind. GPS should be a lot more accurate, (if good weather prevails) because strictly speaking you have only one moving party, the car. Contrary to that you have two moving parties in radar, the car and of course the radar gun. Irrespective of how well trained the operator is, he still has to aim and "contact" a particular area on a car that is moving toeward him ( or away), decreasing or increasing, the distance.Thus he is moving continuasly to maintain his aim. Nobody will ever,ever know wether the officer did not have a slight shake on any givrn moment in his aiming. Even the units on tripods are handled. Only the vertical plane may be still then.
Always learning
Good Answers: 918
05/07/2010 10:34 AM
"Because strictly speaking you have only one moving party, the car."
No, no, no! GPS is fraught with errors as the constellation of satellites is always moving and positions are not always optimal, ionospheric conditions are changing, which does impact signal path, and issues with what is called multipath.
As I posted earlier, GPS has an accuracy, at best, of 15 meters for a car's GPS unit.
I personally find the velocity component pretty good, but it's not dependable for some of the reasons I cited.
I have some knowledge in the field because I worked on systems for aircraft and "precision approach" autopilot landing systems using GPS as the primary positioning source for lat/lon and vertical height. The integrity of these systems are far beyond what you find in the car and still lack the absolute accuracy that you can get with either Doppler radar or laser radar speed guns.
However, I am not saying GPS is not good since it can successfully land an aircraft, its velocity component is not going to reach the precision a radar gun can achieve.
Good Answers: 16
05/12/2010 2:37 PM
Personal observation & 1-time "calibration" with police laser: GPS is spot-on (Garmin Nuvi 200). Personal opinion is that GPS gives me an excellent indication of speed in open areas, good enough that I'll know when the traffic cops are doing something wrong.
Having said that, I think that only the type of GPS that keeps a tracking log over small time intervals will suffice for a court of law, as then you can see speed over distances, in the exact area you were caught. It allows you to state your speed at a place and time. This can be analysed and verified by an expert, and could probably cast enough doubt on the radar system - if the expert does indeed agree! However, only the upper models allows this, and their default storage interval may be too low to be of use.
Radar/laser is difficult to challenge: operator is usually believed, as he is certified & radar device too. But certification does not automatically mean that 1) the operator is using the device correctly or 2) that the device is still functioning correctly (I'm also certified to drive a car, yet I can make mistakes.)
Good luck deciding, your honour!
05/07/2010 3:29 AM
One point that has not been addressed is that the driver may have been convinced that he was doing 96mph. If this was in error and his real speed was 105mph then it could have been a calibration fault in his speedometer (if he was relying on that). If he was relying on the GPS then in my view he has no leg to stand on (if his speedometer was showing the right speed that is). In that case technically the only thing to do is to verify if the speedometer of the car is calibrated correctly. I don't know legally where the driver would stand if his speedometer would be found way out but I would think that he would have a good reason to sue the car manufacturer. I believe that in the past there have been cases where speedometers were not calibrated correctly by the manufacturer and were showing underspeed (i.e. 55mph when they were doing 60mph). The manufacturer was taken to court and failed his defence. Since then speedometers are always calibrated on the safe side (i.e. showing 60mph when they are really doing 55mph). Also, accurracy of the reading reduces at higher speeds which is why for example in the netherlands justice allows for 3kmh + 10% of speedlimit in favour of the speed offender.
'There is no such thing as a silly question, only silly answers' - Unknown
05/07/2010 3:48 AM
For what it's worth I would believe the GPS over the radar gun, if you can be sure that the data has not been tampered with. As Jim pointed out
There is a huge difference between resetting the data and editing the data. You should get someone who really understands the GPS unit in detail to assess the possibility of tampering and examine all the data in detail.
I would also treat is as an opportunity to get to play with the radar gun (I don't know what your "budget" is here): take it to a disused airfield or race track with an expert and some trusted colleagues and see how easy/difficult it is to get erroneous results by moving your aim up and down/side to side fractionally whilst taking a reading.
05/07/2010 3:58 AM
Dear friend!
the result of a GPS measuring is a statistical answer coming out from a lot of calculations. The result may be from diluted, reduced, accuracy because of weather and somthing like disturbances. A civil GPS result is never more precise then +- 15 meters, as long as you do not use differential senders, this will improve the results and make them for about +-5 meters precise. A military used GPS delivers informations with an accuracy +-50 millimeters.
In the opposite, the radar signal won´t be disturbed in accuracy by clouds, rain and something like.
So the measuring result of radar will the more precise.
oe1shs
05/07/2010 6:25 AM
Trying to think about the accuracy of the speed calculated by the GPS, and nothing else, it would seem that if the GPS was having issues with determining accurate position (the +/- 15m spec) then the speed over any time should fluctuate high and low and that the maximum calculated should always be higher then the actual maximum.
Example:
Sample 1 is accurate
Sample 2 is 5m closer to 1 then is should be = calculated speed is too low.
Sample 3 now reads 2m further away then is should = calculate speed is too high
So I don't see how the GPS calculated maximum speed would ever be less then the actual unless the car only obtained that maximum speed for a fraction of a second, (not likely) or, in this case, the data from the GPS was not the data for this particular speeding excursion.
United States - Member - I am a Yankee Doodle Boy. Engineering Fields - Manufacturing Engineering - Old School is the best school. Safety - ESD - Safety Mgr that keeps the peace Hobbies - DIY Welding - My Motto:
Good Answers: 26
05/07/2010 8:27 AM
I would like to interject a different line of thought to this whole process.
Having taken rides with my father in law many times in his cruiser. I came to the understanding of a couple of things.
1. the radar locks onto the largest fastest moving vehicle.
2. The radar can give an improper reading if the gun is a handheld device and is moved in a forward motion towards the vehicle being tagged.
The GPS is easily resettable no matter what type it is and nothing is date stamped.
Those being said I would like to interject that if the vehicle in question is later than a 2005 model, it can be taken to a dealership and a log can be drawn from it giving the highest miles per hour that the car has gone. Dealer use this to verify warranty conditions have not been infringed upon by the owners when making claims.
You may be able to easily settle this by simply having the vehicle inspected at the local dealership and find out what the maximum speed it has been driven to. It wont be hard evidence as to the specific date but it could give you an idea as to whether the vehicle has reached the 105 mph that is in question.
If necessity is the mother of invention then is laziness the mother of necessity?
05/07/2010 8:49 AM
Ignoring the physical cosine error if you motion is not directly on line with the radar, the radar is more accurate. GPS time averages and is not nearly as accuatrate as radar (ignoring the angle error between you and the radar).
Good Answers: 56
05/07/2010 9:32 AM
Prejudice notwithstanding and as much as I'd like to support the driver, I'm inclined to support the readings taken by the officer, I am making certain assumptions in so doing:
  1. that the officer's patrol car or radar unit was itself stationary
  2. that the ticketed driver was the only vehicle in the cone of radar emission.
  3. that the speed measurement was made within the maximum range of the radar unit and for which reflected signal strength and calibration can still be trusted.
A a general rule, high frequency radar units are more precise and more responsive over the short echo ranging distance than changes in satellite signals used by the GPS unit to approximate speed and distance.
L.J.
"Both the revolutionary and the creative individual are perpetual juveniles. The revolutionary does not grow up because he cannot grow, while the creative individual cannot grow up because he keeps growing." Eric Hoffer
Good Answers: 76
05/07/2010 11:21 AM
As both a techie and a Law Enforcement Officer, here is my take on the matter:
(I have not read the entire thread so sorry if any of this has already been covered.)
The fact that this is even being argued scares me as it has the potential to set a significant precedence.
The argument here is not about GPS vs. Radar Gun. It is about a noncalibrated suspect-operated device, which is not designed to measure speed, being able to defeat a calibrated device specifically designed to measure speed that is operated by a trained law enforcement officer under the sole intent of ensuring public safety.
Technical/Legal Arguments:
Speed limits are set and enforced to whole number values of speed in MPH. As such, RADAR, LIDAR, and LASER speed measurement devices are designed and calibrated to be accurate to <+/- 1 MPH. This is to ensure an exact whole number speed value. This is critical as a 1 MPH variation can determine the difference in Point Assessment, Reckless Operation, etc.
Many States have threshold limits at 20+ over posted, and 100+ MPH, regardless of posted. Because a 1 MPH variance can affect the assessed penalty, measurement devices must be accurate to a value smaller than the enforceable increment.
GPS's are designed to identify position. Speed values displayed on a GPS are derived from a secondary operation, not a primary operation.
GPS derived speed estimates are not accurate to a <+/- 1 and thus can not be used to measure to whole number increments
Law Enforcement Officers are trained and certified in the operation of the device.
Suspect GPS owners are neither trained nor certified in the operation of their device.
Law Enforcement speed detection devices are calibrated and recalibrated, within a certain time frame, by an outside firm. That time frame is developed to insure the device is checked well within a timeframe that any designed degradation can occur.
Consumer GPS devices are neither calibrated, nor recalibrated by an independent source.
Law Enforcement Officers verify the calibration of the device both before and after it is used to verify a suspect's speed.
Consumers do not verify the accuracy of the GPS device and can only assume it is correct.
Operational guidelines of Law Enforcement devices require additional recalibration of the device if it subjected to any incident which could affect it's operation (e.g. dropped, coffee spilled on it, etc) This insures that the Law Enforcement device is always in optimal operating conditions.
Consumers are neither trained to know what type if incidences could affect the operation of their GPS, nor are required to replace/repair should any incident occur.
Law Enforcement officers are trained regarding conditions that can affect a device's operation... (heavy rain, fog, heavy traffic, engine compartment movement, etc.) As the Transmitter, Suspect Vehicle, and Receiver are all in close proximity, the ability to identify, document, and debate all potential adverse conditions is available.
Conditions that can, and have shown to affect the operation of a GPS device are not limited to the immediate area of the Officer and the suspect and therefore can not be identified, documented, and debated.
When a Law Enforcement Officer uses a speed detection device, it's make, model, and serial number are discoverable. The records of calibration, training and certification are discoverable. In short, all training and technical documentation related to the speed measurement device and it's operation, in addition to the specifics of 100% of the surrounding environmental conditions are discoverable. This allows for 100% of all potential components of the speed measurement to be identified, evaluated, and debated. This provides both sides access to all potential influences in order to prove/disprove guilt.
This is not possible with a GPS system.
To the Original Poster, this is an important case... I would enlist the help of every resource you can find and I am glad that you are even looking at technical forums.
Please come back again and let us know the outcome of the case and maybe even a summary of the arguments provided by both sides.
Good luck!
JavaHead
05/07/2010 7:56 PM
Sir, Whilst I agree that you have a difficult job, and I would not change rolls with you, I have seen the other side of the force here on Oz. Too many times people have been booked at speed over and above the actual capable speed the vehicle is capable of achieving. Ie: a vehicle was clocked at 138Km/hr when the car in every test under the judge forced the officer to trial in the impounded car and the very best he could achieve was 119km/hr in the test track. This made a mockery of the certified and supposedly duly calibrated speed gun and the correctly trained officer then also had to admit the gun could not have read the reading of 138km/hr. The vehicle had been impounded from the time of the alleged offence until the time the judge ordered the test be done with the co-operation of the vehicle owner. The gun was duly rechecked and found to be accurate. The weather conditions of the day may have been a limiting factor as were the road site conditions with rail lines across the roadway and locomotives on the side of the road, lights with 2 x 10" diameter quartz halogen tungstun ablaze (required by the department to be illuminated at all times the locomotive is running) large hording signage, severe patched road surface of differing texture, and the area is prone to mirage conditions over 300 metres.
The officer and meteorological department verified the day was at 43 degrees celcius (109.4F) with intermittent cloud cover just prior to a torrential thunderstorm that damaged the area just minutes later. There was also high levels of static in the atmosphere and the officer agreed that he had been 'zapped' when he placed his hand on the vehicle when issuing the infringement notice.
I don't know if this is conditions that you would operate under, but the officer was and is a known friend of mine and is quite believable as a diligent and honest person. He is very hesitant to be in charge of Lidar and Laser guns anymore and stated that the police force have a duty forced on them to achieve a certain number of tickets per month and the current affairs program have bought this to the public on a few occasions with the applicable government department denying it is a revenue raising monster of the government.
I have my own personal take on RADAR, Lidar, Laser and other types of speed entrapment machines, that none can be trusted under all setup conditions at all times outside the laboratory conditions.
05/07/2010 11:27 AM
I concur with Anonymous Hero as the most inclusive best GA, and too others were good adders.
I would think the sampling rate of the GPS (Garmin) would be key, certainly much greater (not to be confused with better) than the radar. P.s.: I used to calibrate radar guns.
By the way, the OP was not asking for opinions about excessive speed.
Good Answers: 76
05/07/2010 11:36 AM
From the Garmin site itself:
"The software is provided on an "as is" basis without warranty of any kind -- either expressed or implied -- including, without limitation, any implied warranties of merchantability or fitness for a particular purpose. Garmin does not warrant the performance of the software or that the software will meet your requirements or operate error free."
The above is the warrenty statement of the GPS's Firmware. A pretty strong arguement against the GPS from the manufacturer itself. I will keep digging and post more as I find it to assist in this matter.
JavaHead
05/07/2010 3:53 PM
Man up and pay the fine. In the future drive like you have some sense.
05/07/2010 3:57 PM
Read the post. Better to remain silent and be thought of as a fool than to say something and remove all doubt.
05/09/2010 1:43 AM
When all is said any timing devise that must be accurate needs to be checked periodically against the national standard to determine its accuracy. I believe police speed radar guns must be re-certified periodically. I would suspect the same criteria should be applied to the GPS. Till the timing devise, whether GPS or radar, is certified, its readout must be considered anecdotal evidence.
Good Answers: 918
In reply to #66
05/09/2010 7:23 AM
GPS receivers do not have an internal clock, they use the satellite data for the clock.
No receiver calibration is ever required.
In reply to #69
Re: GPS & Doppler
05/09/2010 9:48 AM
I have not studied the contents of any GPS chipset, and have not disassembled any GPS receiver, so I'm quite willing to be corrected if I'm wrong, but I strongly suspect that most, if not all, GPS receivers use an internal quartz clock to determine when to take a set of values from the various satellites (when to update). For those that calculate velocities, the time between updates is a required value, and I suspect that value comes from the internal clock.
Quartz clocks (oscillators) are quite cheap, and commonly have 5 or more digits of precision, so any errors due to the internal clock would be insignificant compared to other errors in the system.
Good Answers: 918
In reply to #72
Re: GPS & Doppler
05/09/2010 10:24 AM
I stand corrected. Most GPS receivers just divide the oscillator used for the microprocessor to get a rudimentary time. They don't have a real time clock or if they do, they belong as part of a bigger system. The clock is not intended to be very accurate, but is still used as part of the pseudo range (PR and PRR) calculations.
What I meant was that the actual GPS time is not part of the receiver clock, but a corrected time sent from the satellites. The correction of time is applied after the position has been satisfactorily determined and the ranges to each satellite calculated.
The range calculation also has a host of error correction applied to it.
Good Answers: 42
In reply to #74
Re: GPS & Doppler
05/09/2010 10:49 AM
I am curious about the relation between the absolute position accuracy and the calculation of velocity. So far it appears it is assumed the speed calculation is determined for short periods of time and displacement. I have seen the error window shown +/- 15 to 50 meters, but the position reading does not "jump around" in that window.
Depending on the speed algorithm (lets assume it is not instantaneous between every reading), then the absolute position error could become negligible. Example: reading a shaft position with an absolute encoder that has a +/- 5% error. If I take 2 readings and use that to calculate instantaneous velocity I can have very large errors. However, if we take 1000 shaft revolutions only the first and last positon errors are accumulated, the other 1000 revolutions are absolute, so the percentage accuracy of an average speed or total shaft revolution count inproves with the higher counts.
The same thing woud occur with the GPS. The first position may be out +/- 15 meters, and the last position may be out +/- 15 meters, but if the total position change and elapsed time are large, the relative error diminishes.
Good Answers: 918
In reply to #75
Re: GPS & Doppler
05/09/2010 12:53 PM
That's a good point. The position variation is a product of the military's Selective Averaging (SA), which changes slowly, so velocity will be far less effected.
In reply to #75
Re: GPS & Doppler
05/09/2010 1:48 PM
You do indeed have a good point, for constant, or slowly changing, or average velocities. Your shaft could have started and stopped several times during the 1000 Revs, and your data would not reflect those changes.
In the case at hand, the measurements in question are either instantaneous or peak values, neither of which can benefit from value averaging.
Good Answers: 123
05/10/2010 9:21 AM
In my humble opinion.
Speed detectors that are in use by police agencies today have been under the scrutiny of every trial lawyer from sea to shining sea. Any that could not stand that abuse have been removed from the market. There is an entire industry that has evolved to prove that someone is speeding. As good as GPS systems may be, they have not had to withstand the close inspection that the successful "radar guns" have. That may happen some day, but right now, there is just no support system for the GPS units.
Bob
Register to Reply 80 comments
Ace Boeringa (1); Anonymous Hero (14); Anonymous Poster (12); Bill ML (1); bob c (2); courtroom1 (2); crimich13 (2); dkwarner (5); double_j_b (1); Dutchy (1); edignan (1); gideon (1); GW (4); himart (1); JavaHead (2); Jim_Wright (1); jvrj (2); Kilowatt0 (3); Laughing Jaguar (1); logan (1); lyn (7); Mikerho (1); oe1shs (1); otha (3); Randall (1); Shawn33 (1); Tad (2); tecmate (2); Tornado (3); wpenrose (1)
