Previous in Forum: Gear Pump Lubrication   Next in Forum: Pipe Welded - Calculating Max Temp & Pressure
Shrink Fits
05/06/2010 2:03 PM
I need to create an interference fit between a Ø.7500-7505 shaft consisting of alum 6061 t-6511 and a Ø.7495-.7500 journel consisting of 17-4 stainless. In freezing the 6061 t-6511 how much shrinkage will occur and will it be enough to where i wont have to heat the 17-4 journal?
Re: shrink fits
05/06/2010 2:31 PM
Thermal expansion (and contraction) of Al 6061 is 23.4x10-6/°C.
Re: Shrink Fits
05/06/2010 4:18 PM
For the math impaired, 23.4 X 10^-6 = 0.0000234, so if you can freeze the shaft to say -25c your math would look like this:
-25c + 20c (room temp) = -45c (Delta change in temp)
so we have -45 x 0.0000234 = - .001053 change in size
so .7505 - .001053 = .749447
and it will clear.
to answer your question... go to -25c
Re: Shrink Fits
05/07/2010 11:11 AM
THANK YOU FOR THE INFO IT WAS EXACTLY WHAT I NEEDED
Re: Shrink Fits
05/07/2010 3:35 PM
I'll give Labyguy a GA for you. That's customary when you get the answer you needed.
Re: Shrink Fits
05/07/2010 9:32 PM
Well, it should be customary; but alas it isn't....
Anonymous Poster (1); Labyguy (1); lyn (2); Tornado (1)
