Previous in Forum: D.C - D.C converter   Next in Forum: 11KV 1Cx630sqmm XLPE Cable
D.C - D.C converter
05/07/2010 8:02 AM
how to charge capacitor to 15kV in less than 2seconds
Re: D.C - D.C converter
05/07/2010 8:22 AM
To what percentage level?
99% of the charge voltage will be there in the time represented by the capacitance multiplied by the supply impedance multiplied by 5.
http://en.wikipedia.org/wiki/Time_constant
05/07/2010 8:28 AM
Shuffle feet on carpet
05/07/2010 11:24 AM
Ouch! That hurt!
05/07/2010 1:56 PM
SHOCKING! Simply shocking.
Good Answers: 119
05/07/2010 1:14 PM
RC charging is usually slow and very inefficient. What is your capacitor value?
The resonant inverter style power supplies designed specifically to quickly and efficiently charge capacitor banks and pfn's are your best bet. Some examples here...
http://www.us.tdk-lambda.com/hp/product_html/high_volt.htm
05/07/2010 2:11 PM
It all depends on the value of the R and the value of the C. Don't forget that unless your wiring uses only superconducting material you will always have a non-zero value for R.
Good Answers: 119
05/07/2010 2:56 PM
RC charging puts 50% of the energy into the capacitor and 50 % into the resistor and is time limited by the RC time constant (typically 3 to 5 RC seconds). Switching and resonant chargers use reactive elements to transfer the energy to the target capacitor. Obviously never 100% efficient, they can exceed 90% efficiency and can also reduce the charge time by an order of magnitude or more.
If the OPs capacitor is large and the short charge time is critical, then the added expense of a resonant charger may be justified.
Anonymous Poster (1); Doorman (1); mjb1962853 (2); PWSlack (1); redfred (2)
