In our Steam turbine we have Journal bearings, hydrodynamic lubrication.
During Coasting up and coasting down to support the lub oil film,Jacking oil pumps are cutted in ,which gets cut off as the speed increases.
My question is that what will be the effect of Jacking oil pump,if it is not getting cut out at higher rpm.
Will there be any unstablity to lub oil film,effect on vibration pattern.
How this external lub pressure will effect the stable lub oil film developed due to hydrodynamic lubrication.
Normally The jacking oil pump gets cutoff and cut in at 600 rpm during coasting up and coasting down resp.What will happen if I allow to cut in the pump at higher rpm say of 2000 rpm during coasting down.
In my opinion it should not be allowed,I think it will make lub oil film unstable
Any Comments????
Regards
BSJhala
