Previous in Forum: Length of Electric Poles   Next in Forum: AutoCAD Civil 3D Alignments
12 comments
Moisture Content of Soils
05/12/2010 11:22 AM
Hello everyone,
I'm trying to establish a correlation between the conventional (oven drying) method of moisture content determination and the rapid (field) method of moisture content determination of a cohesive material, but I am having some difficulties coming out with this correlation. PLEASE HELP ME.
Re: Moisture Content of Soils
05/13/2010 2:07 AM
The conventional oven method is a 'golden standard'. In addition there are (among others):
Electrical resistance
Neutron absorbtion
IR reflection.
Each method's success depends on lots of variables and any method should be well calibrated before using it's results. If you Google and Wiki these methods you'll have an idea about their applicability in your particular case.
In agriculture (probably the most widespread use of this type of measurement) electrical resistance calibrated for local condition is the preferred method.
Constant change is here to stay!
05/13/2010 4:05 AM
Do you mean: you've got the data, and don't know what to do with it:-
In which case try Excel.
Or, are you looking for possible field solutions:-
in which case dovy's answer looks good.
Good Answers: 29
05/13/2010 10:53 AM
We must know which field test method you are using.
If you are using a nuclear density gage that is equipped with an offset function, you can program it to compute the moisture content based on the results of your oven drying tests. If not you can hand calc, i.e. add or subtract the difference between the field test and the lab test. Even if the relationship is not linear, as long as you are testing soils in the same moisture range (+/_ 2%), the accuracy should not be too bad. Say 0.2 or 0.3 percent. That should be sufficient for determining in place density of the soil; if that's what you're doing, which is something else you should let us know.
One field test method dovy left out was the "Speedy Moisture Test." This test uses a reagent (calcium carbide) that reacts with the moisture in the soil to produce a gas (acetylene) causing a pressure increase in the test vessel. The indicated pressure is then compared to a chart for the soil type you are testing to obtain the moisture content. This test has good repeatability and compares well with oven drying for moist soil types.
Let us in on the field test method, and why you are testing plastic material, and we will try to help you out.
Si vis pacem, para bellum
05/14/2010 9:51 AM
the field method is the use of the speedy meter
Good Answers: 29
05/14/2010 1:11 PM
The Speedy should give accurate results as long as there is not a lot of large aggregate (passing no. 4 sieve). Make sure you continue to roll the balls until the sample is completely broken down and has had a chance to come in contact with the reagent. I always pour out the contents and examine for moist clumps of material, and always check the cap for any of the original sample that may not have fallen into the vessel.
Another factor that is critical is weighing of the sample. Older models have a balance with no zero (tare) adjustment. I have had to add or remove metal from the cup occasionally when they didn't zero with the check weights.
And finally have the pressure gage calibrated frequently. A six month schedule is required by our test procedure; but due to mishandling, more frequent cal. is often necessary.
If you're following the test procedure and your equipment is in good working condition you should get accurate results for the material you described.
Let us know if you discover if any of the items I suggested are the culprit, or if not let me know so I can be aware of any problems I might encounter.
05/15/2010 9:42 AM
The Speedy meter i'm using is quite old. It was purchased about 3 years ago but had never been used. Could this be the problem? Also, is there a specified amount of calcium carbide i was supposed to use?
Good Answers: 29
05/15/2010 10:10 AM
The complete unit should have a scoop for measuring the calcium carbide. Two scoops is typical, but this measurement is not critical, you just need to make sure you have enough reagent available in the vessel to react with ALL the water.
Here is a link to the procedure we use in Florida: FM 5-507
I would definitely calibrate the unit after being idle for 3 yrs.
Hope this helps
05/15/2010 10:21 AM
Thanks so much PMoon, you have been so helpful.
05/16/2010 2:46 PM
PMoon, please one more thing; can you tell me the principle behind the speedy tester?
Good Answers: 29
05/16/2010 7:19 PM
Both Boyle's Law and Avogadro's principles are a employed with this test method.
Boyle's Law tells us pressure and volume are inversely proportional; therefore more gas in the same volume causes an increase in pressure.
When the calcium carbide reacts with the water in the sample it creates acetylene gas (You can look up the chemical reaction formula for yourself).
Avogadro proved that the same weight of any compound will have the same number of molecules (You can look that up to, but it's not that important). That means; for a given weight of water in the sample only a certain number of water molecules are available to react with the calcium carbide and produce only that much acetylene gas that causes the pressure increase in the vessel. The amount of pressure increase relates to the amount of water in the sample in this way.
Hope this helps as I tried to be concise.
05/18/2010 7:30 AM
You are a life saver! Thanks so much...
05/13/2010 12:19 PM
Register to Reply 12 comments
Anonymous Poster (1); dovy (1); Peakay (4); PMoon (4); Randall (2)
