Previous in Forum: Job-Opportunity: Maintenace Engineer Boiler   Next in Forum: Subsea Training in the USA
AC Voltage Regulator
05/12/2010 11:33 AM
Hi to all
What is the best method to build a 3KVA /220V modern AC voltage Regulator(Sabilizer)
Thanks for your ideas.
Re: AC Voltage Regulator
05/13/2010 4:55 AM
Do you mean a mains filter?
Good Answers: 27
05/13/2010 12:05 PM
Best method will depend on how much regulated output is acceptable and range of input variation that can be tolerated.
vsar
05/15/2010 8:31 AM
Simply not enough valid info to allow for a valid answer.....please supply more.
Good Answers: 119
05/23/2010 10:16 PM
The ferroresonant transformer is one option.
http://en.wikipedia.org/wiki/Voltage_regulator#AC_voltage_stabilizers
http://www.solahd.com/products/powerconditioning/index.htm
These are NOT simple to design and build, but they are robust and reliable devices
Register to Reply 4 comments
Andy Germany (1); mjb1962853 (1); Randall (1); vsar (1)
