Explosives
experts, could this be done?
In
a different thread
http://cr4.globalspec.com/thread/54030?frmtrk=cr4sd&Pg=4#comment565539
I
suggested something that has not received any good reviews. How ever hard I try to understand the hardware
involve trying to stop the oil spill in the Gulf, I always come to the same result/conclusion.
I understand how repulsive the ideas of an
amateur can be. I have no experience in any of the technologies involved. I
just really care and even if I lose face I don't care. Just because I could
embarrass myself has never stopped me voicing an idea/opinion.
Here is my suggestion regarding the oil spill in the Gulf:
Blast the thing
to smithereens.
See the sketch bellow, it might help to convey the idea.
So, what are the
dangers of blowing it all to whatsthename.
It would not
create a tsunami would it?
It would not
trigger an earthquake, would it?
It would kill and
maim less wild life, if any
After putting the hardware in place it would be as
fast as one could say "lets clean up and get on with it", wouldn't
it.
It would save the
cradle of fisheries along thousands of miles of cost line.
Could one not get a computer simulation up
and running, put in the variables/data? Experts should know were they drill
that second hole (the one with the charges) and what the geology is like on
site. That would take less time than what is on the table now or was on the table.
I know this is easy to say for me, sitting
here, no responsibility, not much knowledge but a thriving fantasy and the
belief that an explosives expert could calculate what I am on about and at the
same time make sure that the amount and direction of the blast is just right.
If I understand correctly the new well they
are drilling is not only vertical but includes a stretch of (was it 300 feet)
of horizontal line. I mean really, if they can do that, then drilling straight
down for maybe 250 feet, into the bed rock, should be a routine operation.
Drill about 30 feet from the bore hole and
then place the chargers. Now this is what I think will happen, with out any further
leakage which could happen after a single explosion at the water, bed rock
interface would be executed.
1. The first explosion (down 200 feet) will
be aimed at the encased bore hole and flatten it. At the same time loosening
the bedrock above.
2. The second explosion (at 150 feet) will be
powerful enough to loosen bedrock above and hit the bore hole hard by forcing
it against the opposite side of the bed rock. Second crimp, seal.
3. The third explosion (100feet) will just do
the same as the first and second but seal the now created spaces bellow with
bed rock powder or at least very fragmented bits of what ever. Third seal.
4. The fourth explosion would repeat the same
1.2.3 at calculated intervals of time and distance.
5. The last blast (5) would be the most
powerful and seal the gates of hell once and for all.
With all the equipment in place this should
not take too long and as far as I can see (You know, I can imagine things), it
would work. I would be a poor defender of this idea, if I just gave up because
the opposition is just too strong or their quarterback has this cunning ability
to be in the right place at the right time, all of the time. That fountain is still doing what ever it likes. Head down it is
for me, what have I got to lose?
I think that some have just flown over my
comments and have not taken them as they are meant: A work in progress, with
the aim of shutting that bastard of a hemorrhage down as fast as possible and
maybe have a way to do it like that in the future. Have a drill hole for the charges
as part of every rig, if it works.
If it does not work in theory, I'll be the one red
faced but at least I tried, like so many others, just in a different way and more impotently I will have learned something.
Any comments from the Experts?
Hope all goes well, (Pun?), Ky.
Chrisg288 supplied these in a different thread. Imagine that at
5000feet below the surface.
http://www.youtube.com/watch?v=IVQOvKh3IWY
http://en.wikipedia.org/wiki/Ripple_Rock
