Previous in Forum: CU Strip vs Stranded Conductor for Secondary Earthing   Next in Forum: Fuzzy Logic Based Active Power Filter
Changing CT Ration in Ct2e Socomec Kwh Meter
05/12/2010 9:37 PM
hi can any body help me in changing ct ratio in hpl socomec kwh meter of ct2e model
thank u
srinivas
Re: Changing CT Ration in Ct2e Socomec Kwh Meter
05/13/2010 1:33 AM
Why?
Unless somebody goofed in the original specs, changing the CT ratio will make the meter read incorrectly.
Of course, if I could sneak in some CTs of double the ratio, I could cut my electrical bill in half...until I got caught.
05/14/2010 1:54 AM
You have to make sure of the CT ratio installed on site, before changing it on the meter via the software you are using.
If the connection should have a ct ratio of 50/5 and it is programmed 100/5, it means your electricity bill will be doubled and vice versa.
05/14/2010 3:55 AM
Your factor of 2 is correct, but it is applied in the wrong direction.
05/14/2010 5:27 AM
Wrong direction how? With 100/5 my factor would be 20 and with 50/5 my factor would be 10. The CT that I am using always step down the current to 5A.
