Previous in Forum: Time of Use Tariff   Next in Forum: Minimum Conduit Distance in Trench
Rotor Constructing of Squirrel Cage Induction Motor
05/13/2010 3:31 AM
Can any body explain the reasons why the aluminum/copper rods in the rotor of Squirrel cage induction motor design out of line? I mean they are not straight as compare with stator.
Re: Rotor constructing of Squirrel cage induction motor
05/13/2010 4:05 AM
If the bars are axially parallel, there might be small jumps (cogging) as the rotor advances from one bar to the next. A slight twist can allow one bar to fair more smoothly into the next, with a bit of overlap. That's a qualitative layperson's view.
05/13/2010 6:00 AM
Yes ,aluminium /copper rod in the rotor of sq.induction motor is not straight ,due to magnetic locking i.e.coogging .If rod is straight w.r.t. stator slot then ,it may be rod south polarity w.r.t.nearest slot having north pole.then magnetic locking may created between them.max'm starting torque will not created.
05/13/2010 1:46 PM
It also gives better starting torque.
The important thing is not to stop questioning.
05/16/2010 6:15 AM
And maximum starting torque in every position between rotor and stator . I heard that old motor with straight line between rotor and stator slots had bad and loud sound also .
Anonymous Poster (1); Madhusudhana (1); Panta SD (1); Tornado (1)
You might be interested in: Rotor-Stator Mixers, Induction Heaters, Stepper Motors
