Engineering a sub-sea safety caisson with multiple uses for drilling, production, and safety assurances. I have worked in the oil field for many years as a High Pressure Gas Production Specialist. I left the oil field and became a project manager with an emphasis on Industrial Controls.
A Sub-Sea Caisson would be pre fabbed on shore with a center hole large enough to accommodate the current drilling equipment, (ie Blow out Preventer). It would resemble a huge donut. The caisson, ( with re bar welded for strength and heavy duty steel eyes welded on it's surface beams) once placed and anchored at the pre dilling site it would then be filled with concrete up to the multiple eyes and other attachement devices. This caisson with it's massive weight would be used as an anchoring platform to allow a domed structure, (Ribbed inside), to be lowered onto and on top of the well/BOP and attached to the cassion. At the top of the domed structure is an opening to allow for free flow of the well discharge during placement. A heavy duty hinged Gate attached inside the dome,( a thick steel door) with a cable from above attached to the center of this gate would then be pulled up into the flow stream. The pressure from the well and the cable pulling it up would then permanently latch the gate into a sealed position. The massive weight of the caisson that the dome is secured and locked into to would be more than enough to keep the dome in a sealed position. If necessary a flanged one way check valve entrance port 3/4 up the dome could be used to pump in cement and completely encase the BOP prior to the gate being closed.
If there is no problem after the drilling and well completion is finished then the caisson can be used to support production equipment. This caisson can be designed for multiple uses. I have a prototype drawing. It is actually quite simple, I don't see why there isn't this type of process already in place for deep water drilling. But judging from the response of the Various CEO's in the congressional hearing..I'm not surprised. They all seem rather ignorant, naive, and out of touch with the dynamics of pressure, flow, and safety systems. I will post again in the instrumentation section of what kind of industrial control scheme should be in place to automaticlly activate the BOPs regardless of explosions/fire, loss of electric power, or loss of hydraulic communication lines to the drill deck control panel. The logic on this application is also very simple. jovian
