Previous in Forum: Motor Differential Relay Tripping   Next in Forum: Flyback converter question
Electrical Relays
05/14/2010 9:59 AM
Do relays operate in A.C as well as in DC?
Re: Electrical Relays
05/14/2010 10:25 AM
They certainly can. You'll notice that there's a whole lot of listings at any relay vendor site for AC relays and DC relays. Now would you kindly explain to me why you've asked instead of doing some easy to find research yourself?
05/15/2010 1:42 AM
Dear Sir,
You have both the types.Imagine a situation where you have to control
Ac load but you have only a DC source for the relay coil. You will find that the
contacts are rated for AC and DC loads with deratings. This should not be a
problem to be discussed in CR4.
Manroop. Chennai
05/15/2010 7:21 AM
He could have googled DC Relay and seen for hits
05/15/2010 2:24 PM
Dear
We are prefer dc voltage as auxiliary power supply for protection relays because different source from lighting or other ac sources to safe our relays continuously in services to protect the electrical line
thanks
ELSROUGY2003
Register to Reply 4 comments
Anonymous Poster (1); elsrougy2003 (1); manroop (1); redfred (1)
