Previous in Forum: Relay Protection   Next in Forum: Why single phase fan1 speed is > fan2
How We Can Check AVR in Loncin Generator
05/18/2010 12:15 AM
Dears, Salam alikum,
I have a domestic Generator:
Manufacturer:LONCIN (China)
Power Rating: 2KVA (MAX 2.2)
Out put: 220Volt
We have the problem in my generator, it gives 300volts from output.
Now we dismantle the AVR from the generator, but could not understand that how I can check the AVR?
Anybody have some suggestion for checking rapidly.
Waiting....
Munawer Hussain
Re: How we can Check AVR in Loncin Generator
05/18/2010 10:45 AM
We have simulated this in our lab under single fault condition in the voltage feedback and PWM control circuit. It's very likely that the AVR is sourcing to much current to the generator assembly field coil. Since most AVR's are potted or coated you will not be able to fix it, especially without schematics. If you have an extra AVR you can swap it out to see if that fixes it. However, you are very likely to need to replace the AVR anyway.
07/07/2010 5:43 AM
Walaikum Assalam
dear just purchase avr from local market at PKR Rs.250 to 350 and fix it in generator and as avr ckt is covered or coated by magic and other material you can't check on the component level
Register to Reply 2 comments
You might be interested in: Check Valves, Motor and Generator Winding Services
