Previous in Forum: Forced Draft to Clean Fire Tube in Boiler   Next in Forum: Cooling Tower
Hydraulic Hose Pipe
05/18/2010 2:09 PM
What is hydraulic hose pipe and how to defined its type? Send me compleate idea about ordering this for purchase. (What should be mentioned before ordering this )
Re: hydraulic hose pipe
05/18/2010 10:43 PM
You might enjoy exploring this site:
http://www.parker.com/portal/site/PARKER/menuitem.75b3c0354ff8851afa93ebde76108a0c/?vgnextoid=cf36981ef31a0110VgnVCM10000048021dacRCRD
A "compleate" answer to your question would be quite lengthy. Some of the main points would be the pressure of the system, the flow rate through each hose, the type of hydraulic fluid (for chemical compatibility), the end fittings desired, the required length of the hose, etc.
Good Answers: 141
05/19/2010 6:45 PM
Is it a hose, or a pipe or is there a definition for a hosepipe? I don't see the threes in the bush? Thanks
Plenty of room here
Register to Reply 2 comments
You might be interested in: Pipe and Hose Pressing Tools, Hydraulic Hose
