finally I finished installing my 3-phase testing station (based on rotary converter) with variable autotransformer on the output, so I have volts from 0 to 580V.
Now I need an idea for a variable load on the motors that I'll be driving from the VFDs I fix.
I'm thinking about Eddy Current load, variable autotransformer with combination of inductive and resistive load on the output, or may be a rectifier at the output of the drive and then a variable resistor?
The max load will be about 7HP motor.
Any ideas, experiences, advice out there?
TIA
