Previous in Forum: Electric Motor Variable Load   Next in Forum: How to Test for Partial Discharges in Power Transformers
8 comments
Stepper Torque
05/18/2010 5:34 PM
Hi,
Im trying to determine the torque on old steppers from printers for a project Im doing. I cant find specs on these, so im considering tying a string to the shaft and making the stepper lift increasingly heavier weights. Can I burn the motor doing this? Is there any other way of determining this(from the voltage/current/resistance of the motor)?
Thanks,
Re: Stepper Torque
05/18/2010 8:04 PM
If you could know many of the internal parameters of the motor, you could calculate the anticipated torque from the applied voltage and current. But since you don't know even know if these are inductive or permanent magnet motors, it's not worth trying to calculate this. It will be better to just measure the variety of torque values. I seriously doubt that a stepping motor from a printer can be damaged by any stalling action you apply to it. Keep in mind that the available torque will change with the both the current applied and the running speed of the motor.
Re: Stepper Torque
05/18/2010 8:20 PM
Sounds reasonable, thanks. Would salvaging a copier be worth it in terms of max torque? Taking it apart, not to mention even finding one for next to nothing sounds pretty difficult..
Re: Stepper Torque
05/18/2010 9:36 PM
I don't think that either a printer or a copier will have more torque than the other. A slow copier may use a smaller stepper than a fast ink jet printer. Actually the idea of maximizing torque of a stepping motor is almost an oxymoron. Stepping motors work very well in open loop precision motion, where most of the time the motor's rotor inertia is the dominant effective mass being moved. They're also great in open loop configurations for holding a position requires no feedback settings.
Don't forget to retain the driver electronics for the stepping motor. You cannot just apply a DC or AC voltage and have a stepper function.
Re: Stepper Torque
05/19/2010 10:59 PM
If you want high torque, then in my experience older is better. Apple ImageWriter and early LaserWriter printers, as well as early HP LaserJet printers all had size 23 steppers with pretty decent torque. The newer machines are much lighter, so need less torque.
I don't know if you are engineNEAR me, But I still have a working ImageWriter II down in the storage shed - you are welcome to it!
You would have to play for a very long time to damage the motor using its original driver or similar currents..
Good Answers: 109
Re: Stepper Torque
05/20/2010 4:08 AM
Hi,
if you do the test with the same current as the motor is rated you will not burn anything.
If you have only the voltage this is different as at speed the emf-voltage Uind is counteracting the supply-voltage Ubatt so the current is I = (Ubatt-Uind)/Rcoil.
If you have only the maximum allowable housing temperature, then make a test and put some current through the coils, low enough so nothing will be damaged. Measure the housing temperature and the electrical input data, and calculate temperature rise divided by electrical power. This is the thermal resistance of coil to housing. Then scale up the input power until you are at your wanted or allowed housing temperature (by calculation or experiment).
A string is not too good as force transmitter as usually too flexible lengthwise, I prefer a lever with an adjustable weight at adjustable distance.
Have in mind that this torque you want to have is sinusoidal with the angle between rotor and magnetic field vector (not seen in this test). So a force or a torque sensor would be best but your arrangement will do all you need.
At speed the available torque is different depending on the motors resonances and the drive circuit that is used.
This can be better checked in the start-stop-mode if the motor can follow with its torque and rotor-inertia to stepwise changes of drive frequency.
Last test: run at slowly rising frequency with or without external load until the motor stops.
Be careful with calculating and measuring internal power loss as the coil resistance will go up with temperature with near 0.4%/°C.
I did something similar with stepper-motors extracted from 1985? IBM HDDrives (then reputable 20MB!).
Have success!
RHABE
Good Answers: 37
Re: Stepper Torque
05/20/2010 8:27 AM
Put a small drum (sewing thread spool or similar) onto the shaft, with it horizontal. Attach string to it, let it go to floor, where it will attach to one end of light chain piled in a heap. Run the motor, which will lift the string, and the chain; as it continues, it will be supporting more and more chain, until the lifted portion's weight times the lever arm equals the stall torque. If you already know the weight per foot for the chain, a tape measure will quickly provide the weight by measuring from floor to top of chain when the motor stalls. Quick, simple, repeatable (or was when I used the method to test slip torque of a miniature clutch 35 years ago! I can probably still lay hands on the very spool I used . . .). I had a cardboard strip with height marks in ounces next to the string, so that the instant it slipped, I could read the weight and shut off power, letting it unspool and be ready to go again. Sash chain proved suitable for my test; bead chain worked but I needed about 4 strands of it in parallel to get reasonably quick test without mounting the clutch 10 feet in the air.
" Ignorance and arrogance have more in common than their last four letters. "
Re: Stepper Torque
05/20/2010 10:12 AM
Provided you stay within the rated voltage/current/timing of the motor, even holding the rotor still should not damage it.
You should also consider as to whether you want to "step" or "Microstep".......that changes the torque and the smoothness of operation and the frequencies where the motor just stays put!!!!
A good chip will give you all the options you need, I personally prefer the newer Allegro chips for ease of use and easy interfacing....if you want chip numbers just ask me again....
Re: Stepper Torque
05/20/2010 7:11 PM
Great ideas. I think its going to be difficult connecting the shaft to a lever-weight, so im going to make do with a belt (from that same printer) which shouldnt strech much with the weights involved. I though of using a chain, but anything more than 4 links is going to be too much weight... :(
Unfortunately I'm still waiting for my breadboard to arrive, so cant test anything yet.
Register to Reply 8 comments
Andy Germany (1); dkwarner (1); enginenear (2); redfred (2); RHABE (1); Ron (1)
